I recently installed Keil µVision v5. I am interested in seeing if an older project that was built and run in Keil µVision v4 will work without any issue in the newer version of the IDE.
Unfortunately for me, before I can even test that situation, I have been unable to run the example project Hello.c which comes with the IDE. I can build the file without errors being thrown (not a surprise). Yet, the options to run the file or debug it are greyed out which is a surprise (see screenshot). Does anyone have an idea what might be causing this issue? My educated guess is that one or more IDE configuration options are disabled which need to be enabled.
Any help is appreciated! :)
I assume that you just haven't started the Debug session, which the offers to i.e. to Run your application.
Note - another possible reason why features are grayed out is, that you haven't started a matching toolchain (i.e. MDK instead of PK51).
Yes, that is exactly correct. Thank you so much!
