HelloAt the development board NUCLEO-G474RE v Keil (tested version 5.24 and 5.29) flash memory cannot be programmed, when is set in Flash Download checkbox "Erase Sectors".When is set in Options->debug->ST-Link Debugger settings->Flash Download checkbox "Erase Full Chip" all is ok.Someone solved similar problem?
Can you confirm the problem with the CMSIS-RTOS2 Blinky example project offered by MDK's Pack Installer?
This project is pre-configured for ST-Link usage.
Thank you. The example worked as it should, a flash programming error did not occur. I'll check my project settings.
My project is generated from cubemx.
Check the Flash Algorithms and memory addresses selected between working / non-working projects
Check also SWD speed.
