Hello , I'm using Kail MDK 5.29 with the Texas instrument board " LM4F120H5QR " , it was working fine along time ago ....however when i try to recompile some old simple programs using the debugger mode it always enter this FaultISR infinite loop !! ...
As you can see it doesn't show the Local variables and it never get out of this Loop ....I already installed the required Packs , What do you suggest me to do ?
Thank you
HI Am_eng , I tried this but still there is a faultisr
Hi andi , I will check these debugging links
Is your runtime environment configuration is the same as this?
yes it is same only startup version is 1.0.0
Ok, My final advice is to try "Keil_MDK521a", for a reason I don't know why, old versions work well with that board.Good luck
Thank you ill try with this version
