Trying to determine the behavior of the C51 compiler when performing a '>>' on a negative integer.
The C90 indicates that this is compiler implementation dependent.
Will the compiler shift the sign, or does it insert 0's?
Thanks in advance for any replies.
stevea said:C90 indicates that this is compiler implementation dependent
Indeed.
Seems Keil forgot to include the details in the manual:
http://www.keil.com/support/man/docs/c51/c51_xa_behavior.htm
But, surely, you could easily determine this empirically?
You wouldn't even need a real target - the Simulator would do ...
Unfortunately I don't have access to the compiler. The code was written a number of years ago, and the algorithm has since been ported (re-written) to another design. I am not responsible for either design, but am trying to understand why the two systems give different results. I just noticed in the original source that a right shift was being applied to an integer and wanted to confirm it was working as intended.
stevea said:I don't have access to the compiler
Of course you do:
https://www.keil.com/c51/demo/eval/c51.htm
Andy, unfortunately I cannot install any software on my work machine, it all has to be done through our IT department. I was hoping that the question could be answered more quickly by using this forum.
You seem to asking a lot of questions like this, all of which would benefit from having the tools installed.
If it's part of your job, shouldn't your employer be providing appropriate tools ?
EDIT
Sorry - it wasn't you! It was somebody else, but saying a very similar thing.
