I am using HC-05 bluetooth module and STM32F407. I have to enter AT Command Mode and send some AT Commands. Normally, i do it pressing button on the module. But i have to enter AT Command Mode using only software. I can enter AT Command Mode, but i can't send any AT Commands to module. I tried to change the name of the module but it didn't work.
Here is my try. Where is my mistake?
/* USER CODE BEGIN PV */ uint8_t data[50]; /* USER CODE END PV */ static void MX_USART3_UART_Init(void) { sprintf(data,"AT+NAME=charles \n\r"); HAL_UART_Transmit(&huart3, (uint8_t *)data, strlen(data), 2000); }
This has nothing to do with Keil!
AT commands are just about sending & receiving serial data.
So the first thing to do is to get your basic serial comms working.
Once you have basic serial comms working, then it's just a matter of creating the required strings, and sending them; receiving the responses, and parsing them.
But before you do anything in code, practice sending commands to your device manually using a terminal, and observe the responses that you get.
Note that none of this is new - AT commands were long-established and widely-used long before Cortex was even a glint in ARM's eye.
In fact, long before ARM even existed!
eg,
https://www.avrfreaks.net/comment/2209136#comment-2209136
https://www.avrfreaks.net/comment/2783946#comment-2783946
https://www.avrfreaks.net/comment/2212161#comment-2212161
Perhaps some place else..
There is a lot of other code involved in getting the interface and peripheral set up, and some expectations about baud rates, connectivity and responses.
Not good with embedded? Try connecting to a PC terminal via a USB-to-CMOS Serial adapter and walk through the sequences and interactions so you understand them properly.
Does the HC05 expect <CR> <LF> or just <CR>, have you even got the order correct in your string? Remember also sprintf() returns the length.
HAL_UART_Transmit(&huart3, (uint8_t *)data, sprintf(data,"AT+NAME=charles\r\n"), 2000);
What response do you get from the radio? If you leave the output side connected to the USB-to-CMOS Serial adapter you could watch on the PC.
How do other people approach debugging these things? Using scopes or logic analyzers? Understanding what the expectations of the hardware are, and meeting them.
Westonsupermare Pier said:If you leave the output side connected to the USB-to-CMOS Serial adapter you could watch on the PC.
If you have two USB-to-CMOS Serial adapters (or a double adaptor) you could monitor both what the microcontroller sends and what the radio replies:
https://www.avrfreaks.net/comment/2306116#comment-2306116
