I use uVision V5.28.0.0 with ArmClang V6.12 and LPC4367 CPU.
The project compiles without any errors, and flashable output file is generated.
Debug Information and Browse Information is enabled. I did a "Clean Targets".
None of the navigation function (Go to Definition/Declaration/Next Reference) etc. works,only the message "No information available for the selected symbol" is displyed.
This works as expected with V5 compiler.
As a temporary workaroud I use "find in files...".....
Is there a way to fix the problem?
Gunnar
Can you please open a Support Ticket according to: http://www2.keil.com/support/silver
and attach your project, thanks Gunnar
Hello, I have the same issue. Is there a solution to let it working properly in Keil5 uVision?
What version of:
- MDK
- Arm Compiler
do you have installed?
