Hi, Expert
For Keil5.24 GCC compiler, my project got VFP error: xxx uses VFP register arguments, but xxx does not.Actually I added VFP related flags: -mcpu=cortex-m7 -mfpu=fpv5-d16 -mfloat-abi=hard -mthumb.It always calls arm-none-eabi\lib\thumb\v7e-m\nofp libs while compile.
Another compiling environment:MinGW + Cmake +Gcc command prompt with same VFP flags:-mcpu=cortex-m7 -mfpu=fpv5-d16 -mfloat-abi=hard -mthumbIt always calls \arm-none-eabi\lib\thumb\v7e-m+dp\hard while compile and pass
What is the problem? or how can Keil call same compiler lib? Could you help give your suggestion?
Thanks a lot!climber
