I am working with STM32WB55RG platform. I have successfully use printf function with uart. However when I try to use this same function inside cmsis-rtos v2 threads it's not working. Basically thread hangs.
My code implementing printf:
#ifdef __GNUC__ /* With GCC, small printf (option LD Linker->Libraries->Small printf set to 'Yes') calls __io_putchar() */ #define PUTCHAR_PROTOTYPE int __io_putchar(int ch) #else #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f) #endif /* __GNUC__ */ PUTCHAR_PROTOTYPE { /* Place your implementation of fputc here */ /* e.g. write a character to the EVAL_COM1 and Loop until the end of transmission */ HAL_UART_Transmit(&huart1, (uint8_t *)&ch, 1, 0xFFFF); return ch; }
Code starting thread:
// ... osKernelInitialize(); const osThreadAttr_t main_attributes = { .name = "main", .priority = (osPriority_t) osPriorityNormal, .stack_size = 1024 }; mainHandle = osThreadNew(mainFunction, NULL, &main_attributes); osKernelStart(); // ... void mainFunction(void *argument) { uint8_t message[40] = "Hello World! This is mine.\n\r"; for(;;) { printf("Hello this is printf!\n"); //HAL_UART_Transmit(&huart1,message,sizeof(message),10); vTaskDelay(1000/portTICK_RATE_MS); } }
If I remove printf HAL_UART_Transmit works properly. Any thoughts?
Best regards,
zurek
