Does anyone know if it is possible to define an MDK "Custom Tool Menu" item from within a device pack?
- Can you pls explain "Custom Tool Menu" and the idea behind this implementation (before I am going to discuss this with Keil's Engineering)
- See also: https://www.keil.com/pack/doc/CMSIS/Pack/html/cp_SWComponents.html
Thanks for responding.
We are looking to automatically add a new item to the MDK Tools menu from a pack file. This can be done manually from within MDK by selecting Tools | Customize Tools Menu and filling in the dialog.
Can this be automatically inserted from a device pack file?
No, there is no automatic way to get this inserted e.g. when installing the corresponding pack file.
Note that this tools menu is a product specific feature and CMSIS Pack is supported by various IDEs.
You can simplify the configuration for the user by providing a configuration file that the users can import.
Please keep in mind that the path will keep changing each time you release a new version. Therefore it may be better to install the tool that you want to add separately rather than in packs.
~ Joachim
