I m using Eclipse Platform Build id: M20150204-1700, and ULINK Pro and it's connected to the target.
In Debug configuration, the target configuration application on host to download was using .elf file. but the breakpoints are pending so I couldnot debug.
How shall i make the breakpoint to active so that, it can debug codes.
SKM9998 said:I m using Eclipse Platform
So why are you posting in the Keil forum ?
Wouldn't the DS forum be more appropriate: https://community.arm.com/developer/tools-software/tools/f/armds-forum ?
Is this the same issue as your other thread: https://community.arm.com/developer/tools-software/tools/f/keil-forum/44241/cannot-load-axf-file ?
