MDK ARM 5.28 problem with (Reset and Run)
Hello!
I recently updated to Keil MDK 5.28, and everything worked fine till i downloaded my software and try to start it on my board. Upload worked perfectly like on last version (5.26). Then i noticed that board does not start and i found out that my ST-LINK/V2 debugger does not produce reset signal after upload. I checked settings and my (Reset and Run) function is checked and i also put osciloscope on reset pin and result is as expected (no signal after upload). I upgraded STLINK on latest firmware.
Does anyone have same problem?
Thanks for any help!
0
