HI ALL.
I'm working with STM32F103VE and STM32F746, and i want to use my Flash memory as EEPROM EMULATOR for writing and reading data easily.
I have searched for axemples of Emulation of EEPROM for my board but i found exemple of those boards '' STM32F0xx and STM32L4'' and i want to adapt the codes eeprom.h and eeprom.c to my boards.
What i should change? and where?
it's my first time with STM32.
Thank you.
Note that this has nothing specifically to do with Keil - it's about the issues of the ST chips and their particular Flash implementations.
So you'd be better off asking in the ST forums
https://community.st.com/s/
But the "EEPROM Emulation" is entirely internal to the chip - so the board that the chip is on makes no difference at all.
T. Abdelhak said:but i found exemple of those boards
So where are you stuck with adapting those examples to your required chips?
First hit on putting "stm32 eeprom emulation" into google:
AN2594 Application note: EEPROM emulation in STM32F10x microcontrollers
https://www.st.com/content/ccc/resource/technical/document/application_note/ee/ef/d7/87/cb/b7/48/52/CD00165693.pdf/files/CD00165693.pdf/jcr:content/translations/en.CD00165693.pdf
It's also linked from the STM32F103VE Product Page:
