Hello friends
I am trying to generate PWM using TIM4 in STM32F446ZE, But There is no proper output from the controller
Here i am sharing my code with you, please help me out
Counter register increments properly
Specifications
CLK_FREQ =16Mhz (internal)
Timer = TIMER4 and CHANNEL 4
PIN = PD15
PWM freq = 1Khz
Duty cycle = 50%
PWM mode = 1
#include "stm32f4xx.h" // Device header#include "RTE_Components.h" // Component selection
int main(){ RCC->AHB1ENR&=0; RCC->AHB1ENR|=1<<3; // Enable PORT D RCC->APB1ENR&=0; RCC->APB1ENR|=1<<2; // Enable TIMER4 GPIOD->MODER&=0; GPIOD->MODER|=0X80000000; // PD15 as Alternate function GPIOD->AFR[1]&=0; GPIOD->AFR[1]|=1<<28|1<<29; // Alternate function 2 ( AF2) , since PD15 so AFR[1] GPIOD->OSPEEDR&=0; GPIOD->OSPEEDR|=0X80000000; // High Speed output enable TIM4->CCER&=0; TIM4->CCER|=1<<12; // CCP 4 enable ( Since Channle 4) TIM4->CR1&=0; TIM4->CR1|=1<<7; // ARPE enable ( Auto reload preload enable TIM4->CCMR2&=0; TIM4->CCMR2|=1<<14|1<<13|1<<11; // PWM Mode 1 selected and output compare 4 preload enable TIM4->PSC&=0; TIM4->PSC|=16; // prescale as 16 , Since PWM Freq =1Khz TIM4->ARR&=0; TIM4->ARR|=1000; TIM1->CCR4&=0; TIM1->CCR4|=500; //50 % duty cycle
TIM4->BDTR&=0; TIM4->BDTR|=0X8000; TIM4->EGR&=0; TIM4->EGR|=1<<0; TIM4->CR1|=1<<0; // Enable the counter}
