LPC1788 Ethernet with CMSIS RTOS2 RTX5 not working
I am using LPC1788 conrtex M3 microcontroller and trying to configure its e ETHERNET port by using CMSIS RTOS2 RTX5.
I am able to run other drivers like UART , TIMERS , and GPIO's using RTOS2 RTX5.
But facing some issues to run ETHERNET.
microcontroller - LPC1788 M3
Phy IC - LAN8720
Driver - ETH MAC 0
Interface - RMII
IDE and Compiler - Keil microvision-5
software development suite - MDK-Plus
RTOS - RTOS2 RTX5 version 5.5.0
Please find attached c files and Configuration setting I have done in my project.
I am calling netInitialize(); function from main()
it returns me "netOK" that means Network Core initialized successfully
Then I am calling netTCP_GetSocket function and passing "tcp_cb_server" call back function as an argument it as below
tcp_sock = netTCP_GetSocket(tcp_cb_server);
if (tcp_soo itck > 0) {
netTCP_Listen(tcp_sock, 2000);
I am getting tcp_sock = 1,
I am checking status of the socket created "tcp_sock" using function
socket_status = netTCP_GetState(tcp_sock);
it returns me "netTCP_StateLISTEN"
means socket is listen mode.
but when I try to connect through Hyperterminal unable to established a connection
Please find attched code and configuration settings.
Please help on high priority
  • In Pack Installer of uVision, you can find multiple network example projects. Install the latest DFP pack v2.5.0 and copy the "BSD Server" example project as a start. It has been well tested and should work fine.
    Note that these example projects from the DFP v2.5.0 are still based on the old RTXv4.x (CMSIS RTOSv1). You can follow this page to migrate these examples to RTXv5.x (CMSIS RTOSv2)
    https://arm-software.github.io/CMSIS_5/RTOS2/html/os2MigrationGuide.html
    Eventually, only saying "unable to established a connection " won't help much at all. You can follow this article to enable network debug output so that you can know at which point your program failed http://www.keil.com/support/docs/3982.htm
  • I would first use the command line and first try to ping your boards IP. Then use a freeware program such as PacketSender, setup your Local Network for your boards IP (192.168.0.xx) where xx is different than your boards IP. Then open Wireshark and sniff the Local Connection for traffic.
    Finally, your Ethernet connector should have LEDs on the plug. Check for them to flash which signifies data exchange is ongoing.
    The board PHY chip should come up and operate with no changes required. Good luck.
  •  Dear sir,
    Thanks for the reply. I have one doubt related to net_initialize function. when I enter Main() function I am first calling Kernel initializing function and
    below that I am just calling netinitialize function. I am not doing any other ethernet initialization.
    So is it ok, or do I need to add additional code / function for ehternet initialization or netinitilize handles everything.
    please check below code and setting which I have made in my project.
    int main (void) {
        SystemCoreClockUpdate();
        osKernelInitialize();                                        // Initialize CMSIS-RTOS
        netInitialize();
        tid_myUART1_Thread = osThreadNew(uart_one_thread, NULL, NULL); // Create application main thread
        if (tcp_sock > 0) {
        osKernelStart(); // Start thread execution
        for (;;) {}
    Manage Run Time Environment setting NET_Config_ETH_0.h
    Thanks & Regards,
    Amit Dalvi
  • dear sir,
    Thanks for the reply.. I tried to ping my device through command line.
    i am getting reply as "Destination source unreachable".
    Ethernet connector LED keeps blinking all the time.
    Thanks & regards
    Amit Dalvi
