uVision 5 - System Viever cannot display anything for LPC810
I installed the latest uVision 5 from the scratch (needed to replace the laptop with new one) and for some reason I cannot see anything in System Viewer for LPC810 MCU.
I believe that my old uV5 instance worked fine for a few years.
In the 'Target' setting 'System Viewer File :' field is empty (no SVD file set here).
The LPC810 MCU is marked as depreciated in this tab. The latest Software pack is installed (Keil.LPC800_DFP.1.10.0).
I do not have any issue with downloading the code and programming.
I do not have such issues for other MCUs as  STM32.
  • I installed the latest pack and tested the simulator now (the simulator was also affected) as I have no access to the LPC810 board a the moment.
    The simulator works fine now. So it is very likely that the debugger will work fine as well. I'll be testing this later today.
    Thank you for very fast help.
