Hi All, In the ARM toolchain, there is such a thing as linker-defined symbols and could be identify with the delimiter $$ "The linker defines some symbols that contain the character sequence $$. T hese symbols, and all other external names containing the sequence $$, are names reserved by ARM." So when checking the ARM generated map file.. i could just look for $$ . Question :How about when using L251? for this toolchain do we have such thing as linker defined symbols? and if yes, how could i identify them in the mapfile?
The L251 can generate symbols in various ways but they don't have a common syntax like in the Arm linker. I remember the following cases where the L251 generates symbols:
- When 'Linker Code Packing' is enabled, symbols with the name ?L?COM... are generated (see http://www.keil.com/support/man/docs/l251/l251_in_code_packing.htm)
- When code banking is used, the bankswitch routines for functions are generated where necessary. Code banking is supported in L251 but rarely used. See www.keil.com/.../l251_ls_classic_banking.htm
- Some symbols for some segments are generated and marked in the MAP file with '**L251 GENERATED **'. See www.keil.com/.../l251_ln_mapfile.htm. Example:
?C?CODESEG . . . . . . NUMBER ** L251 GENERATED **
- Symbols for Class and Segment information which can be used in C source files. See: http://www.keil.com/support/man/docs/l251/l251_ls_srom.htm
thank you again sir for the reply
