Hey everyone,
I recently purchased an ADuC847 eval board, and am very green when it comes to coding in assembly and/or C. I have several questions when it comes to figuring out the code syntax, and small details which I'm most likely missing. I'm trying to figure out how to take three different analog measurements and output them (~1sec delay) in an ASCII character string such as (AxxxxxByyyyyCzzzzz). I've got the output looking like this so far: AxxxxxxByyyyyyCzzzzzz. If someone could advise me on how to reduce the x,y,z outputs from 6 to 5, hopefully without causing inaccurate readings, that would be great.
The other issue I'm having is that I am struggling with turning on the other analog inputs of the device, or if I turn them on, its displaying the same measurement three times. The code that I have placed below is very basic, and was started with the example code that came with the software.
I've also tried to write a delay program, but insofar I've only got it to freeze after outputting the string. Thoughts? The code doesn't include an attempt to turn on the other analog inputs, I originally tried it in using only ASM51, but have since switched to C and am not sure how to proceed with accomplishing that task.
My code is as follows:
#include <stdio.h> #include <string.h> #include <stdlib.h> #include <ctype.h> #include <ADuC847.h> //Some of these include files may not be necessary sbit LED = 0x0B4; void delay(int); void ADC_int () interrupt 6 { LED ^= 1; printf("\n\n"); printf("A%bX%bX%bX",ADC0H,ADC0M,ADC0L); //This will output 21 ASCII digits. printf("B%bX%bX%bX",ADC0H,ADC0M,ADC0L); //Needs to be reduced to 19 characters printf("C%bX%bX%bX",ADC0H,ADC0M,ADC0L); //Need to reduce from 21 characters to 19 for(;;) { P3 ^= 0x10; delay(10); } } void delay(int length) { while (length >=0) length--; } void main (void) { //Configure UART PLLCON = 0x90; T3CON = 0x82; //115200 Baud rate T3FD = 0x2D; SCON = 0x52; //CONFIGURE ADC AND START CONVERTING.... ICON = 0x01; //Turn on IEXC1 source to drive RTD. SF = 0x200; ADC0CON1 = 0x22; //Full Buffer, Unipolar, 80mV range. ADC0CON2 = 0x4A; //Refin+/-, Ain1->Ain2 EADC = 1; //Enable ADC Interrupt EA = 1; //Enable Global Interrupts ADCMODE = 0x23; // continuous conversion on Main channel on main channel //WAIT FOR INTERRUPTS.... while(1); }The following is the output:
The A,B,C are required as part of my task so I cannot simply rid my code of the output here.
I'll do what I can to answer any questions you all have. Thanks for your time.
Hello mknoob11,
It sounds like you are trying to format the integers printed out by the printf function in a different way. You might want to check pages like these
... for some general ideas.
You also are playing with a delay function. Rather than writing your own delay, you could use an RTOS to handle that, and the switching See the examples in the C:\Keil_v5\C51\RtxTiny2\Examples\ folder
You can read more about this simple to use RTOS here in the RTX51 Tiny User's Guide
Good luck with your 8051 project.
