LPC55S69 SWO connect fails with "Cannot access memory"
I am using KileMDK 2.85 with Jlink to connect to LPC55S69 M33 board. I can download the code and debug but if I enable the "Trace" in the Trace Tab, the debug session fails with "Cannot Access Memory" dialog box. I contacted JLink and they responded with
"This is most likely due to an incorrect SWO init.
As that sequence is issued by Keil uVision which is not our product we can't assist you here. We suggest contacting Keil support in this case."
What is the solution?
