I am currently working on keil, with NUCLEO L053R8 from STMicroelectronics, and I face this issue
(Error: Flash Download failed - "Cortex-M0+")
since I have begun to use ST32CubeMX.
I have already tried to :
- change com port,
- change the nucleo board,
- re-flash the binary file into the MCU,
- flash with "BOOT0" high,
but it has not change anything.
Maybe someone can help me.
Have a good day.
julienM said:since I have begun to use ST32CubeMX
So if you go back to a project from before you started using Cube, does that still work?
You haven't mentioned it - I assume you are using the on-board ST-Link ?
Can you connect & download using ST's ST-Link Utility?
julienM said:change com port
The COM port is not used for debug or programming
Make sure CubeMX doesn't have some default setting that is disabling the SWD debug interface/pins
Also that you haven't mis-configured your Cube project to disable the SWD debug interface/pins
