Dear all,
Would you help me to identify which header file to use with Silabs EFM8LB12F64E?
I already tried to compile a very simple program , but, failed.
#include <SI_EFM8LB1_Register_Enums.h>
sbit LED_Green = P1^4;
sbit LED_Blue = P1^5;
sbit LED_Red = P1^6;
sbit PB0 = P0^2; //Push Button 0
sbit PB1 = P0^3; //Push Button 1
MCU_init(){
// TO disable watchdog timer do following
WDTCN = 0xDE;
WDTCN = 0xAD;
//now, watchdog disabled
CLKSEL = 0x88; // Set system clock to 24.5 MHz
//assign inputs
P0MDIN=P0MDIN | 0x0C; //set bit 2 and 3 of P0 for DI
P0MDOUT=P0MDOUT & 0xF3; // clear bit 2 and 3 of P0 for Open Drain
P0^2 = 1;
P0^3 = 1;
//assign outputs
P1MDIN=P1MDIN | 0x70; //set bit 4, 5 and 6 of P1 for DO
P1MDOUT=P1MDOUT | 0x70; // set bit 4, 5 and 6 of P1 for Push-Pull
main()
MCU_init();
while(1){
if ( PB0 ^ PB1 )
LED_Green=1 ;
else
LED_Blue = PB0 ;
LED_Red = PB1;
Build operation resulted in following errors :
Build target 'Target 1' compiling main.c... ..\main.c(1): warning C318: can't open file 'compiler_defs.h' ..\SI_EFM8LB1_Defs.h(34): warning C318: can't open file 'si_toolchain.h' ..\SI_EFM8LB1_Defs.h(39): error C141: syntax error near '0xE0' ..\SI_EFM8LB1_Defs.h(40): error C141: syntax error near '0xB6' . . . ..\SI_EFM8LB1_Defs.h(543): error C141: syntax error near '0xD8' ..\SI_EFM8LB1_Defs.h(544): error C141: syntax error near '0xD8' ..\main.c(5): error C202: 'P1': undefined identifier ..\main.c(6): error C202: 'P1': undefined identifier ..\main.c(7): error C202: 'P1': undefined identifier ..\main.c(8): error C202: 'P0': undefined identifier ..\main.c(9): error C202: 'P0': undefined identifier ..\main.c(13): error C202: 'WDTCN': undefined identifier ..\main.c(14): error C202: 'WDTCN': undefined identifier ..\main.c(18): error C202: 'CLKSEL': undefined identifier ..\main.c(21): error C202: 'P0MDIN': undefined identifier ..\main.c(22): error C202: 'P0MDOUT': undefined identifier ..\main.c(23): error C202: 'P0': undefined identifier ..\main.c(23): error C141: syntax error near '=' ..\main.c(24): error C202: 'P0': undefined identifier ..\main.c(24): error C141: syntax error near '=' ..\main.c(27): error C202: 'P1MDIN': undefined identifier ..\main.c(28): error C202: 'P1MDOUT': undefined identifier ..\main.c(37): error C202: 'PB0': undefined identifier ..\main.c(39): error C202: 'LED_Green': undefined identifier ..\main.c(43): error C202: 'LED_Blue': undefined identifier ..\main.c(44): error C202: 'LED_Red': undefined identifier Target not created. Build Time Elapsed: 00:00:01
It is obvious that the compiler cannot understand register names.
Please, help me to identify.
Best regards!
