Usb failed packets
What could be causing failed packets
Connection Status Device connected
Current Configuration 1
Speed Full
Device Address 1
Number Of Open Pipes 0
Device Descriptor NXP LPC17xx Speaker
Offset Field Size Value Description
0 bLength 1 12h
1 bDescriptorType 1 01h Device
2 bcdUSB 2 0200h USB Spec 2.0
4 bDeviceClass 1 00h Class info in Ifc Descriptors
5 bDeviceSubClass 1 00h
6 bDeviceProtocol 1 00h
7 bMaxPacketSize0 1 40h 64 bytes
8 idVendor 2 1FC7h
10 idProduct 2 4005h
12 bcdDevice 2 0100h 1.00
14 iManufacturer 1 01h "NXP Semicond "
15 iProduct 1 02h "NXP LPC17xx Speaker "
16 iSerialNumber 1 03h "DEMO00000000"
17 bNumConfigurations 1 01h
Configuration Descriptor 1 Bus Powered, 100 mA
0 bLength 1 09h
1 bDescriptorType 1 02h Configuration
2 wTotalLength 2 0076h
4 bNumInterfaces 1 02h
5 bConfigurationValue 1 01h
6 iConfiguration 1 00h
7 bmAttributes 1 80h Bus Powered
 4..0: Reserved  ...00000
 5: Remote Wakeup  ..0.....  No
 6: Self Powered  .0......  No, Bus Powered
 7: Reserved (set to one)
(bus-powered for 1.0)  1.......
8 bMaxPower 1 32h 100 mA
Interface Descriptor 0/0 Audio, 0 Endpoints
0 bLength 1 09h
1 bDescriptorType 1 04h Interface
2 bInterfaceNumber 1 00h
3 bAlternateSetting 1 00h
4 bNumEndpoints 1 00h
5 bInterfaceClass 1 01h Audio
6 bInterfaceSubClass 1 01h Audio Control
7 bInterfaceProtocol 1 00h
8 iInterface 1 00h
Audio Control Interface Header Descriptor
0 bLength 1 09h
1 bDescriptorType 1 24h Audio Control Interface Header
2  7 01 00 01 27 00 01 01
Audio Control Input Terminal Descriptor
0 bLength 1 0Ch
1 bDescriptorType 1 24h Audio Control Input Terminal
2  10 02 01 01 01 00 01 00 00
00 00
Audio Control Feature Unit Descriptor
0 bLength 1 09h
1 bDescriptorType 1 24h Audio Control Feature Unit
2  7 06 02 01 01 03 00 00
Audio Control Output Terminal Descriptor
0 bLength 1 09h
1 bDescriptorType 1 24h Audio Control Output Terminal
2  7 03 03 01 03 00 02 00
Interface Descriptor 1/0 Audio, 0 Endpoints
0 bLength 1 09h
2 bInterfaceNumber 1 01h
6 bInterfaceSubClass 1 02h Audio Streaming
8 iInterface 1 00h
Interface Descriptor 1/1 Audio, 2 Endpoints
0 bLength 1 09h
3 bAlternateSetting 1 01h
4 bNumEndpoints 1 02h
8 iInterface 1 00h
Audio Streaming Interface Descriptor
0 bLength 1 07h
1 bDescriptorType 1 24h Audio Streaming Interface
2  5 01 01 01 01 00
Audio Streaming Format Type Descriptor
0 bLength 1 0Bh
1 bDescriptorType 1 24h Audio Streaming Format Type
2  9 02 01 01 02 10 01 40 1F
00
Endpoint Descriptor 03 3 Out, Isochronous, 1 ms
0 bLength 1 09h
1 bDescriptorType 1 05h Endpoint
2 bEndpointAddress 1 03h 3 Out
3 bmAttributes 1 05h Isochronous, Asynchronous, Data
 1..0: Transfer Type  ......01  Isochronous
 3..2: Sync Type  ....01..  Asynchronous
 5..4: Usage Type  ..00....  Data
 7..6: Reserved  00......
4 wMaxPacketSize 2 0012h 18 bytes
6 bInterval 1 01h 1 ms
7 bRefresh 1 00h
8 bSynchAddress 1 83h
Audio Streaming Isochronous Audio Data Endpoint Descriptor
0 bLength 1 07h
1 bDescriptorType 1 25h Audio Streaming Isochronous Audio Data Endpoint
2  5 01 00 02 00 00
Endpoint Descriptor 83 3 In, Isochronous, 1 ms
0 bLength 1 09h
2 bEndpointAddress 1 83h 3 In
3 bmAttributes 1 01h Isochronous, No Sync, Data
 3..2: Sync Type  ....00..  No Sync
4 wMaxPacketSize 2 0003h 3 bytes
7 bRefresh 1 01h
8 bSynchAddress 1 00h
http://pastebin.com/gbdKGnwQ
URB     0006-0003       4:11:41.526     6.746 ms        71 us   Sync Reset Pipe and Clear Stall                         01:01:83        83DEC6F0h       USBPDO-5        usbhub  84E65E00h       Success (Success)
URB     0007-0002       4:11:41.526     6.749 ms        88 us   Sync Reset Pipe and Clear Stall                         01:01:83        83DC8C80h       0000007a        usbccgp 84E65E00h       Success (Success)
URB     0008    4:11:41.526     6.758 ms                Isoch Transfer  3 bytes buffer          in      01:01:83        83DC8C80h       0000007a        usbccgp 84FD5790h
URB     0009    4:11:41.526     6.763 ms                Isoch Transfer  3 bytes buffer          in      01:01:83        83DEC6F0h       USBPDO-5        usbhub  84FD5790h
URB     0010-0009       4:11:41.526     6.831 ms        69 us   Isoch Transfer                  in      01:01:83        83DEC6F0h       USBPDO-5        usbhub  84FD5790h       Unsuccessful (Internal HC Error)
URB     0011-0008       4:11:41.526     6.834 ms        77 us   Isoch Transfer                  in      01:01:83        83DC8C80h       0000007a        usbccgp 84FD5790h       Unsuccessful (Internal HC Error)
URB     0012    4:11:41.526     6.847 ms                Sync Reset Pipe and Clear Stall                         01:01:83        83DC8C80h       0000007a        usbccgp 83DD4008h
URB     0013    4:11:41.526     6.853 ms                Sync Reset Pipe and Clear Stall                         01:01:83        83DEC6F0h       USBPDO-5        usbhub  83DD4008h
URB     0014-0013       4:11:41.526     6.889 ms        36 us   Sync Reset Pipe and Clear Stall                         01:01:83        83DEC6F0h       USBPDO-5        usbhub  83DD4008h       Success (Success)
URB     0015-0012       4:11:41.526     6.892 ms        45 us   Sync Reset Pipe and Clear Stall                         01:01:83        83DC8C80h       0000007a        usbccgp 83DD4008h       Success (Success)
