Usb failed packets
What could be causing failed packets
Connection Status Device connected
Current Configuration 1
Speed Full
Device Address 1
Number Of Open Pipes 0
Device Descriptor NXP LPC17xx Speaker
Offset Field Size Value Description
0 bLength 1 12h
1 bDescriptorType 1 01h Device
2 bcdUSB 2 0200h USB Spec 2.0
4 bDeviceClass 1 00h Class info in Ifc Descriptors
5 bDeviceSubClass 1 00h
6 bDeviceProtocol 1 00h
7 bMaxPacketSize0 1 40h 64 bytes
8 idVendor 2 1FC7h
10 idProduct 2 4005h
12 bcdDevice 2 0100h 1.00
14 iManufacturer 1 01h "NXP Semicond "
15 iProduct 1 02h "NXP LPC17xx Speaker "
16 iSerialNumber 1 03h "DEMO00000000"
17 bNumConfigurations 1 01h
Configuration Descriptor 1 Bus Powered, 100 mA
0 bLength 1 09h
1 bDescriptorType 1 02h Configuration
2 wTotalLength 2 0076h
4 bNumInterfaces 1 02h
5 bConfigurationValue 1 01h
6 iConfiguration 1 00h
7 bmAttributes 1 80h Bus Powered
 4..0: Reserved  ...00000
 5: Remote Wakeup  ..0.....  No
 6: Self Powered  .0......  No, Bus Powered
 7: Reserved (set to one)
(bus-powered for 1.0)  1.......
8 bMaxPower 1 32h 100 mA
Interface Descriptor 0/0 Audio, 0 Endpoints
0 bLength 1 09h
1 bDescriptorType 1 04h Interface
2 bInterfaceNumber 1 00h
3 bAlternateSetting 1 00h
4 bNumEndpoints 1 00h
5 bInterfaceClass 1 01h Audio
6 bInterfaceSubClass 1 01h Audio Control
7 bInterfaceProtocol 1 00h
8 iInterface 1 00h
Audio Control Interface Header Descriptor
0 bLength 1 09h
1 bDescriptorType 1 24h Audio Control Interface Header
2  7 01 00 01 27 00 01 01
Audio Control Input Terminal Descriptor
0 bLength 1 0Ch
1 bDescriptorType 1 24h Audio Control Input Terminal
2  10 02 01 01 01 00 01 00 00
00 00
Audio Control Feature Unit Descriptor
0 bLength 1 09h
1 bDescriptorType 1 24h Audio Control Feature Unit
2  7 06 02 01 01 03 00 00
Audio Control Output Terminal Descriptor
0 bLength 1 09h
1 bDescriptorType 1 24h Audio Control Output Terminal
2  7 03 03 01 03 00 02 00
Interface Descriptor 1/0 Audio, 0 Endpoints
0 bLength 1 09h
2 bInterfaceNumber 1 01h
6 bInterfaceSubClass 1 02h Audio Streaming
8 iInterface 1 00h
Interface Descriptor 1/1 Audio, 2 Endpoints
0 bLength 1 09h
3 bAlternateSetting 1 01h
4 bNumEndpoints 1 02h
8 iInterface 1 00h
Audio Streaming Interface Descriptor
0 bLength 1 07h
1 bDescriptorType 1 24h Audio Streaming Interface
2  5 01 01 01 01 00
Audio Streaming Format Type Descriptor
0 bLength 1 0Bh
1 bDescriptorType 1 24h Audio Streaming Format Type
2  9 02 01 01 02 10 01 40 1F
00
Endpoint Descriptor 03 3 Out, Isochronous, 1 ms
0 bLength 1 09h
1 bDescriptorType 1 05h Endpoint
2 bEndpointAddress 1 03h 3 Out
3 bmAttributes 1 05h Isochronous, Asynchronous, Data
 1..0: Transfer Type  ......01  Isochronous
 3..2: Sync Type  ....01..  Asynchronous
 5..4: Usage Type  ..00....  Data
 7..6: Reserved  00......
4 wMaxPacketSize 2 0012h 18 bytes
6 bInterval 1 01h 1 ms
7 bRefresh 1 00h
8 bSynchAddress 1 83h
Audio Streaming Isochronous Audio Data Endpoint Descriptor
0 bLength 1 07h
1 bDescriptorType 1 25h Audio Streaming Isochronous Audio Data Endpoint
2  5 01 00 02 00 00
Endpoint Descriptor 83 3 In, Isochronous, 1 ms
0 bLength 1 09h
2 bEndpointAddress 1 83h 3 In
3 bmAttributes 1 01h Isochronous, No Sync, Data
 3..2: Sync Type  ....00..  No Sync
4 wMaxPacketSize 2 0003h 3 bytes
7 bRefresh 1 01h
8 bSynchAddress 1 00h
http://pastebin.com/gbdKGnwQ
URB     0006-0003       4:11:41.526     6.746 ms        71 us   Sync Reset Pipe and Clear Stall                         01:01:83        83DEC6F0h       USBPDO-5        usbhub  84E65E00h       Success (Success)
URB     0007-0002       4:11:41.526     6.749 ms        88 us   Sync Reset Pipe and Clear Stall                         01:01:83        83DC8C80h       0000007a        usbccgp 84E65E00h       Success (Success)
URB     0008    4:11:41.526     6.758 ms                Isoch Transfer  3 bytes buffer          in      01:01:83        83DC8C80h       0000007a        usbccgp 84FD5790h
URB     0009    4:11:41.526     6.763 ms                Isoch Transfer  3 bytes buffer          in      01:01:83        83DEC6F0h       USBPDO-5        usbhub  84FD5790h
URB     0010-0009       4:11:41.526     6.831 ms        69 us   Isoch Transfer                  in      01:01:83        83DEC6F0h       USBPDO-5        usbhub  84FD5790h       Unsuccessful (Internal HC Error)
URB     0011-0008       4:11:41.526     6.834 ms        77 us   Isoch Transfer                  in      01:01:83        83DC8C80h       0000007a        usbccgp 84FD5790h       Unsuccessful (Internal HC Error)
URB     0012    4:11:41.526     6.847 ms                Sync Reset Pipe and Clear Stall                         01:01:83        83DC8C80h       0000007a        usbccgp 83DD4008h
URB     0013    4:11:41.526     6.853 ms                Sync Reset Pipe and Clear Stall                         01:01:83        83DEC6F0h       USBPDO-5        usbhub  83DD4008h
URB     0014-0013       4:11:41.526     6.889 ms        36 us   Sync Reset Pipe and Clear Stall                         01:01:83        83DEC6F0h       USBPDO-5        usbhub  83DD4008h       Success (Success)
URB     0015-0012       4:11:41.526     6.892 ms        45 us   Sync Reset Pipe and Clear Stall                         01:01:83        83DC8C80h       0000007a        usbccgp 83DD4008h       Success (Success)
  • This code did not seem to do anything when trying on windows vista
    void USB_SOF_Event (void) {
    uint32_t current_timer_count;
      uint32_t feedback_value;
      uint32_t pclk;
                                                    // feedback
      current_timer_count = LPC_TIM1->TC;           // capture current SOF timing on the Timer1
      if ( USB_AltSetting[1] == 1 ) {               // When interface 1 / alt 1 is enabled,
                                                    // calculate master/SOF frequency ratio in 10.10 (10.14) format
    //    feedback_value = ((current_timer_count - last_timer_count) << 14) / (pclk/DATA_FREQ);
        feedback_value = 32 << 14;    // test value for 32k sampling
                                                    // and send it to the feedback IN EP
        USB_WriteEP( 0x83, (uint8_t *)&feedback_value, 3 );
      last_timer_count = current_timer_count;       // update the last SOF timing
    I try to mod it but can not get it to work
    feedback_value = ((current_timer_count - last_timer_count) (32<< 14) / (pclk/DATA_FREQ);
  • OK, I found a bug of the original Keil example.
    BUG: USB_SOF_Event() is repeatedly called in the interval of around 3us
    It should be called in 1ms interval.
    Solution: Clear SOF (FRAME) interrupt flag in ISR, as follows
    MCB1700 Sample Code Bundle for LPC17xx Peripherals using Keil's MDK-ARM V2.00 (Jan 10, 2011)
    ics.nxp.com/.../mcb1700.code.bundle.lpc17xx.keil.zip
    keil_examples\USBAudio\usbhw.c
    void USB_IRQHandler (void) {
    #if USB_SOF_EVENT
      /* Start of Frame Interrupt */
      if (disr & FRAME_INT) {
        LPC_USB->DevIntClr = FRAME_INT;   // <---- bug fix
        USB_SOF_Event();
    #endif
    Tsuneo
  • Nope did nothing, apart from hang the pc after a couple of seconds of audio.
  • What do these definitions do anyway where is the documentation. the same errors are still happing
    usbreg.h
    /* Device Interrupt Bit Definitions */
    #define FRAME_INT           0x00000001
    #define EP_FAST_INT         0x00000002
    #define EP_SLOW_INT         0x00000004
    #define DEV_STAT_INT        0x00000008
    #define CCEMTY_INT          0x00000010
    #define CDFULL_INT          0x00000020
    #define RxENDPKT_INT        0x00000040
    #define TxENDPKT_INT        0x00000080
    #define EP_RLZED_INT        0x00000100
    #define ERR_INT             0x00000200
  • Hmm,
    On my side, the mods work as we expect.
    Maybe, I didn't touch to all of modifications I made.
    I posted current modification, here.
    www.8052.com/.../MCB1700_USBAudio_Async_32k_r0.zip
    Try this one.
    To run above firmware on MCB1700, touch this line.
    usbdmain.c
    int main (void)
    #define OLIMEX_LPC1766STK   // <--- comment this line for MCB1700
    At this stage, we have examined basic implementation of the feedback endpoint for Async Sink.
    To brush up above implementation, these issues still remain.
    1) Feedback refresh interval
    In above implementation, Windows read out the feedback EP every 11 or 12 frames, Mac does every 8 frames.
    But our firmware refreshes it in every frame.
    We have to change the refresh interval and bRefresh value on sync EP.
    USB Audio Spec, www.usb.org/.../audio10.pdf
    3.7.2.2 Isochronous Synch Endpoint
    The sample clock Fs is always derived from a master clock Fm in the device.
    P is related to the ratio between those clocks through the following relationship:
    Fm = Fs * 2^(P-1)
    As indicated earlier, a new Ff value is available every 2^(10 – P) frames with P ranging from 1 to 9. The
    bRefresh field of the synch standard endpoint descriptor is used to report the exponent (10-P) to the Host.
    It can range from 9 down to 1. (512 ms down to 2 ms)
    2) Variable number of samples per frame
    Async Sink results +/- 1 samples per frame occasionally, when the frequency ratio of
    the local sampling clock and SOF is apart from an integer number.
    But original Keil implementation assumes that the sample number per frame would be constant,
    and this number is power of 2, ie. 1, 2, 4, 8, 16, 32,...
    This assumption is fine for Adaptive/Synchronous Sink, but it is not approved for Async Sink.
    - I touched to the mods for Keils's "mask" method, in this post
    http://www.keil.com/forum/19557/
    Posted 30-Sep-2011 03:43 GMT
    - The mods on above post has to be modified more for variable transferred data size on each frame.
    3) Pop noise on Windows
    Windows irregularly put Set_Interface(0) / Set_Interface(1) pair to the device, while it plays sound.
    This makes pop noise. I'm not sure if this behavior is caused by the value of feedback or not.
    Tsuneo
  • Which one of these should I be changing the feild bInterval and bRefresh for. If you could explain how they both work together would help.
    /* Endpoint - Standard Descriptor */
      AUDIO_STANDARD_ENDPOINT_DESC_SIZE,    /* bLength */
      USB_ENDPOINT_DESCRIPTOR_TYPE,         /* bDescriptorType */
      USB_ENDPOINT_OUT(3),                  /* bEndpointAddress */
      USB_ENDPOINT_TYPE_ISOCHRONOUS | USB_ENDPOINT_SYNC_ASYNCHRONOUS,        /* bmAttributes */          // <-------
      WBVAL(66),                            /* wMaxPacketSize */   // <-------
      0x01,                                 /* bInterval */
      0x00,                                 /* bRefresh */
      0x83,                                 /* bSynchAddress */    // <-------
    /* Endpoint - Standard Descriptor - for feedback */
      USB_ENDPOINT_IN(3),                   /* bEndpointAddress */
      USB_ENDPOINT_TYPE_ISOCHRONOUS,        /* bmAttributes */
      WBVAL(3),                             /* wMaxPacketSize */
      0x01,                                 /* bRefresh */
      0x00,                                 /* bSynchAddress */
    If I set them like this
      0x01,                                 /* bInterval */   <------------------------ Interval for polling endpoint for data transfers expressed in milliseconds  0x01 = 1 packet every frame
      0x09,                                 /* bRefresh */   <----------------------------- 512ms until synchronization pipe provides new synchronization feedback data.
    would that mean I would get 1ms delay for polling data transfers of 1 packet every frame, and then 512ms before the endpoint provides new synchronization feedback data.
    what do you feel they should be set at.
    What are you suggesting to be changed when you wrote these comments, are you talking about audio.h and desc.c WBVAL(66), and P_S Packet Size
    /* Audio Definitions */
    #define DATA_FREQ 32000                 /* Audio Data Frequency */
    #define P_S       32                    /* Packet Size */
    #if USB_DMA
    #define P_C       4                     /* Packet Count */
    #else
    #define P_C       1                     /* Packet Count */
    #endif
    #define B_S       (8*P_C*P_S)           /* Buffer Size */
    Could you give me details about what I am to do here
  • I could not get your code to work with MCB1700 after commenting out the line,
    usb device is unrecognised
    Hmm,
    Try this one.
    usbdmain.c
    int main (void)
    Do you know why
  • > Do you know why
    I don't know :-)
    There aren't so many differences between MCB1700 and OLIMEX_LPC1766STK for this example.
    Just the analog port, to which a pod connects.
    I put the #define into the source, to cover this difference.
    a) Is the original Keil example runs on your MCB1700?
    b) What is the version of Windows?
    c) How doesn't it "work"? Is it enumerated? No sound?, etc
    Tsuneo
  • Could you answer these comments first please. Much more important to me than getting the code you posted to work thankyou.
    #if USB_DMA
    #else
    #endif
  • 1) Feedback refresh interval
    Both of bInterval fields of the OUT and IN endpoints are set to 1 (ms)
    I mean the bRefresh field of the feedback IN EP.
    Host (Windows and Mac) polls the feedback IN endpoint in the interval specified by the bRefresh value, not in 1ms interval.
    USB Audio spec tells the shortest interval is 2 ms (bRefresh = 1)
    But there seems lower limit by OS audio driver implementation,
    MacOSX: 8 ms (bRefresh = 3), and Windows: 11 or 12 ms
    In above implementation, the firmware calculates the feedback value on every SOF interrupt.
    We have to change this behavior.
    When bRefresh = 3, the firmware calculate feedback value in every 8 ms.
    #define FEEDBACK_REFRESH_EXPONENT  3      // bRefresh value for the feedback IN EP (1..9)
    #define FEEDBACK_REFRESH_INTERVAL  (1 << FEEDBACK_REFRESH_EXPONENT)
    uint8_t feedback_refresh_timer = FEEDBACK_REFRESH_INTERVAL;
    uint32_t last_timer_count;
    extern uint32_t sampling_interval;
    #if USB_SOF_EVENT
                                                    // feedback
      if ( --feedback_refresh_timer == 0 ) {
          feedback_value = ((current_timer_count - last_timer_count) << 14) / FEEDBACK_REFRESH_INTERVAL / sampling_interval;
          USB_WriteEP( 0x83, (uint8_t*)&feedback_value, 3 );
    WBVAL(66) (wMaxPacketSize of isoc OUT EP)
    The original example sets this value to WBVAL(64), ie. 32 samples for 32kHz monaural 16bits.
    But MacOSX doesn't put any feedback IN transaction for this value.
    To receive feedback IN transactions, at least WBVAL(66) (32 + 1 samples) is required.
    This modification is required not just for Async Sink, but also for support of fractional sampling rate, such as 44.1kHz
    For DMA implementation of the isoc OUT EP,
    USB_EndPoint3() is called when packet counts (P_C) number of packets are received.
    Packet Info Buffer (InfoBuf array) holds received size of each packets (LSB 2 bytes)
    (refer to "11.15.6 Isochronous endpoint operation" of the LPC17xx manual)
    For slave implementation of the isoc OUT EP, USB_ReadEP() in USB_SOF_Event() returns received packet size.
    In these callbacks (DMA:USB_EndPoint3(), slave:USB_SOF_Event())
    DataIn index increments by actual received packet size, instead of the constant value (P_C*P_S or P_S) of the original.
    A problem lies in the end of the cyclic buffer. It moves around by the extra (or less) sample(s).
    When DataIn reaches near the end of the cyclic buffer, this index is held in a current_end_of_buffer variable.
    And DataIn wraparounds to the top of the buffer.
    In the playback routine (TIMER0_IRQHandler()),
    DataOut wraparounds to the top of the buffer, when it reaches to above current_end_of_buffer.
    Tsuneo
  • With mod you posted for usbuser.c, it does not work until I have to change the bRefresh to 0x03 before it will work.
    /* Endpoint - Standard Descriptor */                       // <-------- additional feedback EP
      0x03,                                 /* bRefresh,  */     //<-------  every 8ms
    in vista for some reason not sure it is bug but it always trys for 2ms even when changes for 8ms, I do get 8ms transfers but for some reason some 2ms transfer do happen and fail:( and I made sure the vid pid were changed as well
    USBlyzer Report
    Capture List
    Type    Seq     Time    Elapsed         Duration        Request         Request Details         Raw Data        I/O     C:I:E   Device Object   Device Name     Driver Name     IRP     Status
    URB     24534-24533     8:29:28.673     17.530532 s     1.383 ms        Isoch Transfer                  in      01:01:83        86F4E6F0h       USBPDO-5        usbhub  86E69E28h       Unsuccessful (Iso Request Failed)
    URB     24535-24532     8:29:28.673     17.530538 s     1.395 ms        Isoch Transfer                  in      01:01:83        86F57C80h       0000009e        usbccgp 86E69E28h       Unsuccessful (Iso Request Failed)
    URB     32498-32497     8:29:34.364     23.222458 s     1.806 ms        Isoch Transfer                  in      01:01:83        86F4E6F0h       USBPDO-5        usbhub  86E69E28h       Unsuccessful (Iso Request Failed)
    URB     32499-32496     8:29:34.364     23.222461 s     1.813 ms        Isoch Transfer                  in      01:01:83        86F57C80h       0000009e        usbccgp 86E69E28h       Unsuccessful (Iso Request Failed)
    Now for win7 even with the bug fix you posted I get these us errors
    URB     0047-0046       8:49:33.314     32.829 ms       53 us   Isoch Transfer                  in      01:01:83        85057030h       USBPDO-5        usbhub  94D72B00h       Unsuccessful (Internal HC Error)
    URB     0048-0045       8:49:33.314     32.832 ms       59 us   Isoch Transfer                  in      01:01:83        867F9A80h               ACPI    94D72B00h       Unsuccessful (Internal HC Error)
    URB     0049-0044       8:49:33.314     32.834 ms       66 us   Isoch Transfer                  in      01:01:83        8699BC68h       00000068        usbccgp 94D72B00h       Unsuccessful (Internal HC Error)
    URB     0191-0190       8:49:33.364     87.787 ms       60 us   Isoch Transfer                  in      01:01:83        85057030h       USBPDO-5        usbhub  94D72B00h       Unsuccessful (Internal HC Error)
    URB     0192-0189       8:49:33.364     87.790 ms       68 us   Isoch Transfer                  in      01:01:83        867F9A80h               ACPI    94D72B00h       Unsuccessful (Internal HC Error)
    URB     0193-0188       8:49:33.364     87.793 ms       78 us   Isoch Transfer                  in      01:01:83        8699BC68h       00000068        usbccgp 94D72B00h       Unsuccessful (Internal HC Error)
    URB     0329-0328       8:49:33.424     143.782 ms      57 us   Isoch Transfer                  in      01:01:83        85057030h       USBPDO-5        usbhub  94D72B00h       Unsuccessful (Internal HC Error)
    and I am getting some 0 packet transfers as well, but I think this is because of the new mods you made to usbuser.c
    URB     0091-0084       9:25:52.942     2.192497 s      7.821 ms        Isoch Transfer  0 bytes data            in      01:01:83        84306030h       USBPDO-5        usbhub  842D0670h       Success (Success)
    URB     0092-0083       9:25:52.942     2.192501 s      7.831 ms        Isoch Transfer  0 bytes data            in      01:01:83        84396020h               ACPI    842D0670h       Success (Success)
    URB     0093-0082       9:25:52.942     2.192504 s      7.839 ms        Isoch Transfer  0 bytes data            in      01:01:83        82124990h       00000071        usbccgp 842D0670h       Success (Succes
    I made the changes for keils's mask method
    does the audio.h need to be modded
    #define P_S       32                    /* Packet Size */  <-------------32  + 1 samples
    #if USB_DMA
    #else
    #endif
  • its a bug with
    sync Reset Pipe and Clear Stall, do you know how to fix
  • After searching the internet, the best I have come with is that, it could have something to do
    with usb.h and adcuser.c
    in windows 7 every 50 to 80 us SYNC_RESET_PIPE_AND_CLEAR_STALL is being issued and failing causing lost packets and out of sync audio packets
    The _URB_PIPE_REQUEST structure is used by USB client drivers to clear a stall condition on an endpoint.
    Syntax
    struct _URB_PIPE_REQUEST { struct URB_HEADER Hdr; USBD_PIPE_HANDLE PipeHandle; ULONG Reserved;
    Members
    Hdr
    Pointer to the _URB_HEADER structure that specifies the URB header information. Hdr.Function must be one of the following:
    URB_FUNCTION_SYNC_RESET_PIPE_AND_CLEAR_STALL
    URB_FUNCTION_SYNC_CLEAR_STALL
    URB_FUNCTION_ABORT_PIPE
    URB_FUNCTION_CLOSE_STATIC_STREAMS
    The Hdr.Length member must be sizeof(_URB_PIPE_REQUEST).
    PipeHandle
    Specifies an opaque handle to the bulk or interrupt pipe. The host controller driver returns this handle when the client driver selects the device configuration with a URB of type URB_FUNCTION_SELECT_CONFIGURATION or when the client driver changes the settings for an interface with a URB of type URB_FUNCTION_SELECT_INTERFACE.
    Reserved
    Reserved. Do not use.
    Remarks
    The reserved members of this structure must be treated as opaque and are reserved for system use.
    Requirements
    Header
    Usb.h (include Usb.h)
     *      U S B  -  K e r n e l
     * Name:    usb.h
     * Purpose: USB Definitions
     * Version: V1.20
     *      This software is supplied "AS IS" without any warranties, express,
     *      implied or statutory, including but not limited to the implied
     *      warranties of fitness for purpose, satisfactory quality and
     *      noninfringement. Keil extends you a royalty-free right to reproduce
     *      and distribute executable files created using this software for use
     *      on NXP Semiconductors LPC family microcontroller devices only. Nothing
     *      else gives you the right to use this software.
     * Copyright (c) 2009 Keil - An ARM Company. All rights reserved.
    #ifndef __USB_H__
    #define __USB_H__
    typedef __packed union {
      uint16_t W;
      __packed struct {
        uint8_t L;
        uint8_t H;
      } WB;
    } WORD_BYTE;
    /* bmRequestType.Dir */
    #define REQUEST_HOST_TO_DEVICE     0
    #define REQUEST_DEVICE_TO_HOST     1
    /* bmRequestType.Type */
    #define REQUEST_STANDARD           0
    #define REQUEST_CLASS              1
    #define REQUEST_VENDOR             2
    #define REQUEST_RESERVED           3
    /* bmRequestType.Recipient */
    #define REQUEST_TO_DEVICE          0
    #define REQUEST_TO_INTERFACE       1
    #define REQUEST_TO_ENDPOINT        2
    #define REQUEST_TO_OTHER           3
    /* bmRequestType Definition */
    typedef __packed union _REQUEST_TYPE {
      __packed struct _BM {
        uint8_t Recipient : 5;
        uint8_t Type      : 2;
        uint8_t Dir       : 1;
      } BM;
      uint8_t B;
    } REQUEST_TYPE;
    /* USB Standard Request Codes */
    #define USB_REQUEST_GET_STATUS                 0
    #define USB_REQUEST_CLEAR_FEATURE              1
    #define USB_REQUEST_SET_FEATURE                3
    #define USB_REQUEST_SET_ADDRESS                5
    #define USB_REQUEST_GET_DESCRIPTOR             6
    #define USB_REQUEST_SET_DESCRIPTOR             7
    #define USB_REQUEST_GET_CONFIGURATION          8
    #define USB_REQUEST_SET_CONFIGURATION          9
    #define USB_REQUEST_GET_INTERFACE              10
    #define USB_REQUEST_SET_INTERFACE              11
    #define USB_REQUEST_SYNC_FRAME                 12
    /* USB GET_STATUS Bit Values */
    #define USB_GETSTATUS_SELF_POWERED             0x01
    #define USB_GETSTATUS_REMOTE_WAKEUP            0x02
    #define USB_GETSTATUS_ENDPOINT_STALL           0x01
    /* USB Standard Feature selectors */
    #define USB_FEATURE_ENDPOINT_STALL             0
    #define USB_FEATURE_REMOTE_WAKEUP              1
    /* USB Default Control Pipe Setup Packet */
    typedef __packed struct _USB_SETUP_PACKET {
      REQUEST_TYPE bmRequestType;
      uint8_t         bRequest;
      WORD_BYTE    wValue;
      WORD_BYTE    wIndex;
      uint16_t         wLength;
    } USB_SETUP_PACKET;
    /* USB Descriptor Types */
    #define USB_DEVICE_DESCRIPTOR_TYPE                  1
    #define USB_CONFIGURATION_DESCRIPTOR_TYPE           2
    #define USB_STRING_DESCRIPTOR_TYPE                  3
    #define USB_INTERFACE_DESCRIPTOR_TYPE               4
    #define USB_ENDPOINT_DESCRIPTOR_TYPE                5
    #define USB_DEVICE_QUALIFIER_DESCRIPTOR_TYPE        6
    #define USB_OTHER_SPEED_CONFIG_DESCRIPTOR_TYPE      7
    #define USB_INTERFACE_POWER_DESCRIPTOR_TYPE         8
    #define USB_OTG_DESCRIPTOR_TYPE                     9
    #define USB_DEBUG_DESCRIPTOR_TYPE                  10
    #define USB_INTERFACE_ASSOCIATION_DESCRIPTOR_TYPE  11
    /* USB Device Classes */
    #define USB_DEVICE_CLASS_RESERVED              0x00
    #define USB_DEVICE_CLASS_AUDIO                 0x01
    #define USB_DEVICE_CLASS_COMMUNICATIONS        0x02
    #define USB_DEVICE_CLASS_HUMAN_INTERFACE       0x03
    #define USB_DEVICE_CLASS_MONITOR               0x04
    #define USB_DEVICE_CLASS_PHYSICAL_INTERFACE    0x05
    #define USB_DEVICE_CLASS_POWER                 0x06
    #define USB_DEVICE_CLASS_PRINTER               0x07
    #define USB_DEVICE_CLASS_STORAGE               0x08
    #define USB_DEVICE_CLASS_HUB                   0x09
    #define USB_DEVICE_CLASS_MISCELLANEOUS         0xEF
    #define USB_DEVICE_CLASS_VENDOR_SPECIFIC       0xFF
    /* bmAttributes in Configuration Descriptor */
    #define USB_CONFIG_POWERED_MASK                0x40
    #define USB_CONFIG_BUS_POWERED                 0x80
    #define USB_CONFIG_SELF_POWERED                0xC0
    #define USB_CONFIG_REMOTE_WAKEUP               0x20
    /* bMaxPower in Configuration Descriptor */
    #define USB_CONFIG_POWER_MA(mA)                ((mA)/2)
    /* bEndpointAddress in Endpoint Descriptor */
    #define USB_ENDPOINT_DIRECTION_MASK            0x80
    #define USB_ENDPOINT_OUT(addr)                 ((addr) | 0x00)
    #define USB_ENDPOINT_IN(addr)                  ((addr) | 0x80)
    /* bmAttributes in Endpoint Descriptor */
    #define USB_ENDPOINT_TYPE_MASK                 0x03
    #define USB_ENDPOINT_TYPE_CONTROL              0x00
    #define USB_ENDPOINT_TYPE_ISOCHRONOUS          0x01
    #define USB_ENDPOINT_TYPE_BULK                 0x02
    #define USB_ENDPOINT_TYPE_INTERRUPT            0x03
    #define USB_ENDPOINT_SYNC_MASK                 0x0C
    #define USB_ENDPOINT_SYNC_NO_SYNCHRONIZATION   0x00
    #define USB_ENDPOINT_SYNC_ASYNCHRONOUS         0x04
    #define USB_ENDPOINT_SYNC_ADAPTIVE             0x08
    #define USB_ENDPOINT_SYNC_SYNCHRONOUS          0x0C
    #define USB_ENDPOINT_USAGE_MASK                0x30
    #define USB_ENDPOINT_USAGE_DATA                0x00
    #define USB_ENDPOINT_USAGE_FEEDBACK            0x10
    #define USB_ENDPOINT_USAGE_IMPLICIT_FEEDBACK   0x20
    #define USB_ENDPOINT_USAGE_RESERVED            0x30
  • /* USB Standard Device Descriptor */
    typedef __packed struct _USB_DEVICE_DESCRIPTOR {
      uint8_t  bLength;
      uint8_t  bDescriptorType;
      uint16_t  bcdUSB;
      uint8_t  bDeviceClass;
      uint8_t  bDeviceSubClass;
      uint8_t  bDeviceProtocol;
      uint8_t  bMaxPacketSize0;
      uint16_t  idVendor;
      uint16_t  idProduct;
      uint16_t  bcdDevice;
      uint8_t  iManufacturer;
      uint8_t  iProduct;
      uint8_t  iSerialNumber;
      uint8_t  bNumConfigurations;
    } USB_DEVICE_DESCRIPTOR;
    /* USB 2.0 Device Qualifier Descriptor */
    typedef __packed struct _USB_DEVICE_QUALIFIER_DESCRIPTOR {
      uint8_t  bLength;
      uint16_t  bcdUSB;
      uint8_t  bReserved;
    } USB_DEVICE_QUALIFIER_DESCRIPTOR;
    /* USB Standard Configuration Descriptor */
    typedef __packed struct _USB_CONFIGURATION_DESCRIPTOR {
      uint8_t  bLength;
      uint16_t  wTotalLength;
      uint8_t  bNumInterfaces;
      uint8_t  bConfigurationValue;
      uint8_t  iConfiguration;
      uint8_t  bmAttributes;
      uint8_t  bMaxPower;
    } USB_CONFIGURATION_DESCRIPTOR;
    /* USB Standard Interface Descriptor */
    typedef __packed struct _USB_INTERFACE_DESCRIPTOR {
      uint8_t  bLength;
      uint8_t  bInterfaceNumber;
      uint8_t  bAlternateSetting;
      uint8_t  bNumEndpoints;
      uint8_t  bInterfaceClass;
      uint8_t  bInterfaceSubClass;
      uint8_t  bInterfaceProtocol;
      uint8_t  iInterface;
    } USB_INTERFACE_DESCRIPTOR;
    /* USB Standard Endpoint Descriptor */
    typedef __packed struct _USB_ENDPOINT_DESCRIPTOR {
      uint8_t  bLength;
      uint8_t  bEndpointAddress;
      uint16_t  wMaxPacketSize;
      uint8_t  bInterval;
    } USB_ENDPOINT_DESCRIPTOR;
    /* USB String Descriptor */
    typedef __packed struct _USB_STRING_DESCRIPTOR {
      uint8_t  bLength;
      uint16_t  bString/*[]*/;
    } USB_STRING_DESCRIPTOR;
    /* USB Common Descriptor */
    typedef __packed struct _USB_COMMON_DESCRIPTOR {
      uint8_t  bLength;
    } USB_COMMON_DESCRIPTOR;
    #endif  /* __USB_H__ */
