C++ project linking problem
Hi everyone,
I created a C++ project and implemented some basic classes. The compilation works fine but in the linking process I get some errors. I don't really know what I do wrong. I assume someone familiar with using C++ and RealView can help.
Here are the error messages I get:
linking...
.\Obj\OrigaII_Test.axf: Error: L6218E: Undefined symbol __aeabi_unwind_cpp_pr0 (referred from new.o).
.\Obj\OrigaII_Test.axf: Error: L6218E: Undefined symbol __rt_new_handler_addr (referred from new.o).
.\Obj\OrigaII_Test.axf: Error: L6218E: Undefined symbol abort (referred from arm_exceptions_terminate.o).
.\Obj\OrigaII_Test.axf: Error: L6218E: Undefined symbol __rt_eh_globals_addr (referred from arm_exceptions_globs.o).
Target not created
Thank you,
Frank
  • MicroLib is a highly-optimized library designed for deeply embedded applications written in C (C++ is not typically used in such applications).
    Since MicroLib is optimized to use less code and data memory, there are some differences from the default C library.
    Look at the following page for details:
    http://www.keil.com/arm/microlib.asp
  • ... thank you for this information!
    Frank
  • When i checked the Micro-Lib, it gives these problems:
    linking...
    .\Temp\LPC2468IPB.axf: Error: L6218E: Undefined symbol __use_two_region_memory (referred from lpc2300.o).
    .\Temp\LPC2468IPB.axf: Error: L6218E: Undefined symbol __initial_sp (referred from entry.o).
    Target not created
    Why?
  • Hi Philip,
    did you implement these functions? If you use the standard Keil example code, these functions are located in the startup file.
    Frank
  • Hi F D
    My startup code is here:
    rapidshare.de/.../LPC2300.s.html
    What i must to add in this startup code?
    Thanks for answer.
  • Hi Philip,
    you should not publish third party source code files, it is legally not correct!
    Here is a part of a startup-code that shows the parts of interest:
    ;  Enter User Mode and set its Stack Pointer
                    EXPORT __initial_sp
     ; Enter the C code -------------------------------------------------------------
                    IMPORT  __main
                    LDR     R0, =__main
                    BX      R0
    ; User Initial Stack & Heap
                    AREA    |.text|, CODE, READONLY
                    IMPORT  __use_two_region_memory
                    EXPORT  __user_initial_stackheap
                    LDR     R0, =  Heap_Mem
                    LDR     R1, =(Stack_Mem + USR_Stack_Size)
                    LDR     R2, = (Heap_Mem +      Heap_Size)
                    LDR     R3, = Stack_Mem
                    BX      LR
                    ENDIF
    Take a look at other startup files in your code samples if you need more info. I hope this helps.
    Frank
  • Hi F D
    Thanks for your opinion.
    I added EXPORT __initial_sp only because i have other codes.
                    EXPORT __initial_sp ; <---- here
                    MSR     CPSR_c, #Mode_USR
                    MOV     SP, R0
                    SUB     SL, SP, #USR_Stack_Size
    ; Enter the C code
                    IMPORT  __main
                    LDR     R0, =__main
                    BX      R0
                    LDR     R0, = Heap_Mem
                    LDR     R1, = (Stack_Mem + USR_Stack_Size)
                    LDR     R3, = Stack_Mem
                    BX      LR
    But, the error message is:
    assembling LPC2300.s...
    LPC2300.s(500): error: A1145E: Undefined exported symbol '__initial_sp'
    The Micro-Lib option is checked.
    What can i do?
  • Again take a look at the startup files provided in your RealView MDK installation (for example Keil\ARM\Startup\Philips\LPC2300.s).
    Missing is the declaration for __initial_sp defined as:
                    AREA    STACK, NOINIT, READWRITE, ALIGN=3
    Stack_Mem       SPACE   USR_Stack_Size
    __initial_sp    SPACE   ISR_Stack_Size
  • Thanks,
    i used LPC2300.s 2006 version, i downloaded new version and the problem is solved.
    Thank you very much again.
