Dear Sir, I am facing a problem in interfacing the AT89C51 with AT24C04 (External memory). the code is as follows:
FADDR EQU 0A0h ; fixed address for AT24Cxx EEPROMs MEM_SIZE EQU 20h ; bytes per AT24C64 FILL EQU 53h ; example fill value SDA EQU P1.2 SCL EQU P1.3 ; Register definitions. addr_ptr EQU r3 ; 8-bit address pointer ORG 0000H ; power on/reset vector SJMP MAIN ORG 0030H MAIN: ;;;;;;;;;;;;;;;;;;;; LCD Part Initialization for Display ;;;;;;;;;;;;;;;;;;;;;;;;; ACALL DELAY MOV A,#30H ;;;; To define 16x2 line character display NOP NOP MOV P2,A NOP NOP CLR P1.4 SETB P1.5 CLR P1.5 ACALL DELAY MOV A,#0CH ;;;; To display cursor on and blinking NOP NOP MOV P2,A NOP NOP CLR P1.4 SETB P1.5 CLR P1.5 ACALL DELAY MOV A,#01H ;;;; To clear the screen NOP NOP MOV P2,A NOP NOP CLR P1.4 SETB P1.5 CLR P1.5 ACALL DELAY MOV A,#80H ;;;; To display from first line NOP NOP MOV P2,A NOP NOP CLR P1.4 SETB P1.5 CLR P1.5 NOP ACALL DELAY MOV A,#06H ;;;; To increment the cursor NOP NOP MOV P2,A NOP NOP CLR P1.4 SETB P1.5 CLR P1.5 NOP ACALL DELAY ;;;;;;End LCDinitialization Part ;;;;;;;; sending the rest of the code in next message:
"Sorry to send it in four parts. The message didnt fit in." There's a clue there! You are trying to debug far too much at once. Your first step must be to reduce this to something really simple, and get that working. Then you can extend & expand it one small step at a time. Be sure that you have each step working before moving to the next step; Always keep a backup of the previous working step. When it stops working, go back to the previous step, examine what you've changed, and deduce where you went wrong.
