Has anyone out there ever used the Keil Monitor De-bugger with an RTX166 program? If so I would like to know how to set it up. Thanks in advance
I used Monitor166 with RTX166 Tiny. Set it up exactly the same way as without RTX166 Tiny. - mike
Did you use an onboard UART to connect to your target? If so did you have any problems with interrupt vectors, I hear RTX166 allocates unused vectors. How does one free up the vectors for the Monitor?
