Hi I am trying to convert a -axf file generated by keil(microvision 5.26.2.0) to binay. The various Keil manuals state that you can do this by entering a command string in Target 1> User tab. The command string I entered is --> C:\Keil_v5\ARM\ARMCC\bin\fromelf.exe --bin --output= "C:\Users\Bhal Laptop 2017\Documents\A Smart Node DECWG (SND) Program\SND M0 Software\SND201V1\Objects\SND201V1.bin" "C:\Users\Bhal Laptop 2017\Documents\A Smart Node DECWG (SND) Program\SND M0 Software\SND201V1\Objects\SND201V1.axf"
The error message I get is -- ? Program Size: Code=1288 RO-data=252 RW-data=36 ZI-data=608 FromELF: creating hex file... After Build - User command #1: C:\Keil_v5\ARM\ARMCC\bin\fromelf.exe --bin --output= "C:\Users\Bhal Laptop 2017\Documents\A Smart Node DECWG (SND) Program\SND M0 Software\SND201V1\Objects\SND201V1.bin" "C:\Users\Bhal Laptop 2017\Documents\A Smart Node DECWG (SND) Program\SND M0 Software\SND201V1\Objects\SND201V1.axf" "C:\Users\Bhal Laptop 2017\Documents\A Smart Node DECWG (SND) Program\SND M0 Software\SND201V1\Objects\SND201V1.bin": Error: Q0122E: Could not open file 'C:\Users\Bhal Laptop 2017\Documents\A Smart Node DECWG (SND) Program\SND M0 Software\SND201V1\Objects\SND201V1.bin': No such file or directory --- The source file (SND201V1.axf) is in the correct folder -- > "C:\Users\Bhal Laptop 2017\Documents\A Smart Node DECWG (SND) Program\SND M0 Software\SND201V1\Objects\SND201V1.axf"
However I do not get SNd201V1.bin file in that folder. What is the problem and how to fix it ? Any help will be appreciated.. THanks. Bhal
http://www.keil.com/forum/64146/
What have you changed since then?
I think the build output would be easier to read is you posted it as for source code.
