Linking errors
I'm getting linking errors while building the application that I couldn't figure out the cause.
I created a function x(&y, &z); which all the code in it is commented.
from my main(), whenever I call this function I get this message:
linking...
.\Output\Release\AD-app.axf: Error: L6406E: No space in execution regions with .ANY selector matching lwip.o(i.__ARM_common_call_via_r1).
.\Output\Release\AD-app.axf: Error: L6406E: No space in execution regions with .ANY selector matching tmwdlist.o(i.__ARM_common_call_via_r4).
.\Output\Release\AD-app.axf: Error: L6406E: No space in execution regions with .ANY selector matching tmwlink.o(i.__ARM_common_call_via_r6).
.\Output\Release\AD-app.axf: Error: L6406E: No space in execution regions with .ANY selector matching iusefp.o(.text).
.\Output\Release\AD-app.axf: Error: L6407E: Sections of aggregate size 0x974 bytes could not fit into .ANY selector(s).
Not enough information to list image symbols.
Not enough information to list the image map.
Finished: 2 information, 0 warning and 78 error messages.
I read about increasing IRAM but it didn't solve the problem.
Any idea on the reason(s) why I'm getting linking errors & how to fix it?
I'm working on STR712FR2 and IRAM1 is 0xB000.
Regards,
BaDeR
  • You didn't felt that the message "Sections of aggregate size 0x974 bytes could not fit" gave a significant hint? Error messages are intended to be read, without a need to involve a forum. By reading the message, you could have solved the problem in minutes instead of having to wait for someone else to respond.
