I am interfacing GSM module with ARM LPC 2148 , when i compiled code in KEIL 4 i am getting these errors please help me . #define CR 0x0D #include <LPC214X.H> #include <stdio.h> void getstring(unsigned char *); int getchar (void) /* Read character from Serial Port */ void status_ok(void); void Serial_Init(void); void delay(unsigned int n); void main(void) { unsigned int cnt=0x80,m; char xx; Serial_Init(); elay(50); while(1) { printf("AT\r"); // AT COMMAND FOR INITIALING status_ok(); printf("AT+IPR=9600\r"); // AT COMMAND FOR BAUD RATE status_ok(); printf("AT+CMGR=2\r"); // Reading the message detail // at Index 1 with phone number, data and time status_ok(); delay(250); printf("ATD9790550124;\r");//AT COMMAND FOR CALL DIALING delay(250); status_ok(); delay(500); delay(500); delay(500); delay(500); delay(500); delay(500); printf("ATH\r"); // AT COMMAND FOR CALL DISCONNECTING delay(250); status_ok(); delay(500); printf("ATDL\r"); // AT COMMAND FOR REDIALING delay(250); status_ok(); delay(500); delay(500); delay(500); printf("ATH\r"); // AT COMMAND FOR ANSWERING THE CALL delay(250); status_ok(); delay(500); delay(500); } }
void getstring(unsigned char *array) { unsigned char temp=0, i=0; do { temp = getchar(); *array++ = temp; } while((temp != '\r') && (temp != '\n')); *array = '\0'; int getchar (void) /* Read character from Serial Port */ { while (!(U0LSR & 0x01)); return (U0RBR); } } void status_ok(void) { getstring(y); while(!(strstr(y,"OK"))) getstring(y); pointr = strstr(y,"OK"); lcd_cmd(0xc0); lcd_data(*pointr++); lcd_data(*pointr); delay(500); lcd_cmd(0x01); } void Serial_Init(void) { PINSEL0 |= 0X00000005; //Enable Txd0 and Rxd0 U0LCR = 0x00000083; //8-bit data, no parity, 1-stop bit U0DLL = 0x00000061; //for Baud rate=9600,DLL=82 U0LCR = 0x00000003; //DLAB = 0; } void delay(unsigned int n) { unsigned int i,j; for(i=0;i<n;i++) { for(j=0;j<12000;j++) {;} } }
compiling gsm.c... gsm.c(5): error: #55: too many arguments in macro invocation gsm.c(5): error: #79: expected a type specifier gsm.c(5): error: #141-D: unnamed prototyped parameters not allowed when body is present gsm.c(6): error: #130: expected a "{" gsm.c(10): warning: #12-D: parsing restarts here after previous syntax error gsm.c(13): warning: #223-D: function "Serial_Init" declared implicitly gsm.c(14): warning: #223-D: function "elay" declared implicitly gsm.c(20): warning: #223-D: function "delay" declared implicitly gsm.c(22): warning: #223-D: function "status_ok" declared implicitly gsm.c(11): warning: #177-D: variable "cnt" was declared but never referenced gsm.c(11): warning: #177-D: variable "m" was declared but never referenced gsm.c(12): warning: #177-D: variable "xx" was declared but never referenced gsm.c(57): error: #268: declaration may not appear after executable statement in block gsm.c(49): warning: #177-D: variable "i" was declared but never referenced gsm.c(57): error: #67: expected a "}" gsm.c(57): error: #55: too many arguments in macro invocation gsm.c(57): error: #79: expected a type specifier gsm.c(57): error: #247: function "getc" has already been defined gsm.c(57): error: #141-D: unnamed prototyped parameters not allowed when body is present gsm.c(62): error: #169: expected a declaration gsm.c(89): warning: #1-D: last line of file ends without a newline gsm.c(89): warning: At end of source: #12-D: parsing restarts here after previous syntax error gsm.c - 11 Error(s), 11 Warning(s).
Please READ the posting instructions and tip when posting source code.
Start by looking at the FIRST error, the others are probably the compiler's unsuccessful attempts to resynchronize.
ADD a semicolon -> int getchar (void) /* Read character from Serial Port */
If i add semicolon also i am getting same error.
So do you have getchar defined as a macro in one of your include files, does it object to the space between the name and the bracket?
