I have a problem with the configuration of Keil microvision 5 with the STM32L Discovery Development board. I set up a template project according to the tutorial present in this page fabioangeletti.altervista.org/.../ that is however for a different version of STM32 board (STM32F0 Discovery). When I click on the build all button, I receive a lot of error messages. Following is a part of the errors list (176 in total). Any suggestion on how to fix it? Thanks in advance.
.\obj\Project.axf: Error: L6200E: Symbol DAC_IRQHandler multiply defined (by startup_stm32l1xx_md.o and startup_stm32l1xx_hd.o). .\obj\Project.axf: Error: L6200E: Symbol DAC_IRQHandler multiply defined (by startup_stm32l1xx_mdp.o and startup_stm32l1xx_hd.o). .\obj\Project.axf: Error: L6200E: Symbol DAC_IRQHandler multiply defined (by startup_stm32l1xx_xl.o and startup_stm32l1xx_hd.o). .\obj\Project.axf: Error: L6200E: Symbol DMA1_Channel1_IRQHandler multiply defined (by startup_stm32l1xx_md.o and startup_stm32l1xx_hd.o). .\obj\Project.axf: Error: L6200E: Symbol DMA1_Channel1_IRQHandler multiply defined (by startup_stm32l1xx_mdp.o and startup_stm32l1xx_hd.o). .\obj\Project.axf: Error: L6200E: Symbol DMA1_Channel1_IRQHandler multiply defined (by startup_stm32l1xx_xl.o and startup_stm32l1xx_hd.o).
Not enough information to list image symbols. Not enough information to list the image map. Finished: 2 information, 0 warning and 176 error messages. ".\obj\Project.axf" - 176 Error(s), 0 Warning(s). Target not created
Pick ONE startup_stm32xxx.s file which is suitable for the chip you are using, ie memory, feature set, etc.
I don't think the problem is compatibility with my development board. The compiler gives these error messages after clicking buil all. No programming operation was performed. However the files were downloaded from the ST web site for my development board.
I don't think the problem is compatibility with my development board. It quite certainly is, for at least one of those source files. Those files might both work for that board, but they appear to be for different CPUs that can be mounted on it.
But you missed Per's main point, which was about having only one of those files in the build.
The compiler gives these error messages after clicking buil all. Strictly speaking, no. It's the linker that gave those messages. There's a difference worth knowing about.
"Error: L6200E: Symbol DAC_IRQHandler multiply defined (by startup_stm32l1xx_md.o and startup_stm32l1xx_hd.o)"
That message seems perfectly clear and explicit - which part don't you understand?
It is telling you that you have two files - startup_stm32l1xx_md.o and startup_stm32l1xx_hd.o - which both contain a definition of DAC_IRQHandler
You need just one or the other - but not both!!
"according to the tutorial present in this page..."
Have you asked the author of that page?
Yes, I asked the author of the tutorial but He does not answer. I think that files with extension.o are generated by the compiler. These are not files I copied in the file directories when I created the template project.
So *.o files are generated by your compiler or part of a library file.
But the collision happens because you have requested a collision.
Like having two *.s files included in the project when expected to instead have selected the *.s file that matched your processor or your evaluation board.
In the end, you have to figure out why the project tries to use competing files. And you have to figure out which file that is the correct one for your target. Just as you, when out driving a car or a bike, have to figure out if you need to turn left or right to avoid hitting a dog in front of you. Being a developer means you can't depend on the net for all your problems - you also have to make own decisions based on the facts available to you. A puzzle has one single solution. Real-world programming problems have many - or even infinite - solutions possible. Which also means that the developer has to make many decisions.
Your project currently has FOUR start up files, pick ONE
startup_stm32l1xx_md.s startup_stm32l1xx_hd.s startup_stm32l1xx_mdp.s startup_stm32l1xx_xl.s
You have a LINKER error indicating you have TOO MANY instances of the same definition. The ASSEMBLER just processes the files you have added to the project, having multiple .S files in a project is not an error, but they should should not replicate the functionality of each other.
ST's templates for Keil on the STM32L-Discovery boards appear to use the MD variant, and defines USE_STDPERIPH_DRIVER STM32L1XX_MD
Correct - but the compiler (or assembler) doesn't just create them out of thin air, does it?
"These are not files I copied in the file directories when I created the template project"
Think how the output files that the compiler (or assembler) generate relate to the input files that you supply...
