Hello I wanted to try out some network tutorials from the rl arm user guide: http://www.keil.com/product/brochures/rl-arm_gs.pdf page 71
I got the same tree in my project: benrichter.ohost.de/tree.png
And im using the lcp1768 from nxp
But i receive a tons of errors so i wonder whats wrong?
I use the free version that i downloaded from the uvision homepage. RTX Works but non of the RL examples
Log:"
Build target 'Target 1' linking... sample.axf: Error: L9937E: RL-ARM is not allowed with this license sample.axf: Error: L6367E: at_ip.o(i.ip_chk_frame) attributes are not compatible with the provided cpu and fpu attributes . sample.axf: Error: L6242E: Cannot link object at_ip.o as its attributes are incompatible with the image attributes. sample.axf: Error: L6367E: at_ip.o(i.ip_get_chksum) attributes are not compatible with the provided cpu and fpu attributes . sample.axf: Error: L6242E: Cannot link object at_ip.o as its attributes are incompatible with the image attributes. sample.axf: Error: L6367E: at_ip.o(i.ip_get_locadr) attributes are not compatible with the provided cpu and fpu attributes . sample.axf: Error: L6242E: Cannot link object at_ip.o as its attributes are incompatible with the image attributes. sample.axf: Error: L6367E: at_ip.o(i.ip_init) attributes are not compatible with the provided cpu and fpu attributes . sample.axf: Error: L6242E: Cannot link object at_ip.o as its attributes are incompatible with the image attributes. sample.axf: Error: L6367E: at_ip.o(i.ip_run_local) attributes are not compatible with the provided cpu and fpu attributes . sample.axf: Error: L6242E: Cannot link object at_ip.o as its attributes are incompatible with the image attributes. sample.axf: Error: L6367E: at_ip.o(i.ip_send_frame) attributes are not compatible with the provided cpu and fpu attributes . ... Target not created "
You wonder what is wrong?
Why?
You say: "I use the free version that i downloaded from the uvision homepage."
Don't you think this error message can be trusted? "sample.axf: Error: L9937E: RL-ARM is not allowed with this license"
See the Note at the foot of this page:
http://www.keil.com/rl-arm/rl-tcpnet.asp
