when i use the Keil V4.24.00.0 compile my project based in R8051,some errors occures;
*** ERROR L121: IMPROPER FIXUP MODULE: .\BIN\interrupt.obj (INTERRUPT) SEGMENT: ?PR?TIMER0_INT?INTERRUPT OFFSET: 0014H *** ERROR L121: IMPROPER FIXUP MODULE: .\BIN\interrupt.obj (INTERRUPT) SEGMENT: ?PR?TIMER0_INT?INTERRUPT OFFSET: 0020H *** ERROR L121: IMPROPER FIXUP MODULE: .\BIN\interrupt.obj (INTERRUPT) SEGMENT: ?PR?TIMER0_INT?INTERRUPT OFFSET: 0022H *** ERROR L121: IMPROPER FIXUP MODULE: .\BIN\main.obj (MAIN) SEGMENT: ?PR?MAIN?MAIN OFFSET: 00CEH *** ERROR L121: IMPROPER FIXUP MODULE: .\BIN\main.obj (MAIN) SEGMENT: ?PR?MAIN?MAIN OFFSET: 00D1H *** ERROR L121: IMPROPER FIXUP MODULE: .\BIN\PLC.obj (PLC) SEGMENT: ?PR?PLCSEND?PLC OFFSET: 0004H *** ERROR L121: IMPROPER FIXUP MODULE: .\BIN\PLC.obj (PLC) SEGMENT: ?PR?PLCSEND?PLC OFFSET: 0007H
but using the V4.02.00.0,it's OK.
and some project has also problems like error C202
compiling main.c... main.c(11): error C202: 'P0': undefined identifier main.c(12): error C202: 'P0': undefined identifier main.c(13): error C202: 'P2': undefined identifier main.c(15): error C202: 'P2': undefined identifier main.c(16): error C202: 'P2': undefined identifier main.c(17): error C202: 'P2': undefined identifier main.c(18): error C202: 'P2': undefined identifier main.c(20): error C202: 'P3': undefined identifier main.c(21): error C202: 'P3': undefined identifier main.c(22): error C202: 'P1': undefined identifier main.c(23): error C202: 'P1': undefined identifier main.c(62): error C202: 'P0M1': undefined identifier
anyone who can help me please contract my Email 526946899@qq.com
thanks
What does this have to do with ARM?!
about KEIL
So when your car doesn't start, you go to the correct car repair shop. But you do say "window" to them just to make it obvious that your problem isn't with any window but with the car starting?
I recommend you contact the Technical Support (http://www.keil.com/support). Please do not forget to specify your valid product serial number.
