Hi
I'm having trouble with my 2nd CAN block on the LPC2364. The initialization goes fine (CAN2MOD is set to 0x00 in the end), but when I want to send a CAN message, it disables the CAN block by the transmission request. What could be the cause of it. The hardware works fine, idem for CAN block 1. When I step trough the code, CAN block 1 don't disable the CAN 1 operation mode. What's the difference with CAN 2?
This is my init and transmist code:
void initCAN() { // turn on power of CAN blocks: bit 13/14 of PCONP PCONP |= 1 << 13; // CAN 1 PCONP |= 1 << 14; // CAN 2 // P0.21 and P0.22 for CANRx1 and CANTx1 (TD1, RD1) = 11 PINSEL1 |= 0x3C00; // P0.4 and P0.5 for CANRx2 and CANTx2 (TD2, RD2) = 10 PINSEL0 |= 0xA00; CAN1MOD = CAN2MOD = 0x01; // Reset CAN CAN1IER = CAN2IER = 0x00; // Disable Receive Interrupt CAN1GSR = CAN2GSR = 0x00; // Reset error counter when CANxMOD is in reset // Baudrate Prescaler CAN1BTR = CAN2BTR = 0x7E0001; // 500K IODIR0 |= 1<<20; // CAN1_TXEN = output IOCLR0 |= 1<<20; // CAN1_TXEN = low --> activate transceiver IODIR0 |= 1<<6; // CAN2_TXEN = output IOCLR0 |= 1<<6; // CAN2_TXEN = low --> activate transceiver CAN1MOD = CAN2MOD = 0x00; // CAN in operating mode installInterruptCAN(0x17, 0xFF, (void *)canHandler); //0x17 = 0d23 CAN1IER = CAN2IER = 0x01; // enable receive interrupts }
int TransmitHandler(MESSAGE *sendMsg, U8 can) { if(can == 0x01){ volatile unsigned status = CAN1SR; if(status & 0x04) // Transmit buffer 1 released { //RTR, long or short ID & DLC CAN1TFI1 = sendMsg->Frame & 0xC00F0000; CAN1TID1 = sendMsg->canID; CAN1TDA1 = sendMsg->DataA; CAN1TDB1 = sendMsg->DataB; // Transmission Request on TX Buffer 1 CAN1CMR = 0x21; return 1; } else if(status & 0x400) // Transmit buffer 2 released { //RTR, long or short ID & DLC CAN1TFI2 = sendMsg->Frame & 0xC00F0000; CAN1TID2 = sendMsg->canID; CAN1TDA2 = sendMsg->DataA; CAN1TDB2 = sendMsg->DataB; // Transmission Request on TX Buffer 2 CAN1CMR = 0x41; return 1; } else if(status & 0x40000) // Transmit buffer 3 released { //RTR, long or short ID & DLC CAN1TFI3 = sendMsg->Frame & 0xC00F0000; CAN1TID3 = sendMsg->canID; CAN1TDA3 = sendMsg->DataA; CAN1TDB3 = sendMsg->DataB; // Transmission Request on TX Buffer 3 CAN1CMR = 0x81; return 1; } else return 0; } else if(can == 0x02){ volatile unsigned status = CAN2SR; if(status & 0x04) // Transmit buffer 1 released { //RTR, long or short ID & DLC CAN2TFI1 = sendMsg->Frame & 0xC00F0000; CAN2TID1 = sendMsg->canID; CAN2TDA1 = sendMsg->DataA; CAN2TDB1 = sendMsg->DataB; // Transmission Request on TX Buffer 1 CAN2CMR = 0x21; return 1; } else if(status & 0x400) // Transmit buffer 2 released { //RTR, long or short ID & DLC CAN2TFI2 = sendMsg->Frame & 0xC00F0000; CAN2TID2 = sendMsg->canID; CAN2TDA2 = sendMsg->DataA; CAN2TDB2 = sendMsg->DataB; // Transmission Request on TX Buffer 2 CAN2CMR = 0x41; return 1; } else if(status & 0x40000) // Transmit buffer 3 released { //RTR, long or short ID & DLC CAN2TFI3 = sendMsg->Frame & 0xC00F0000; CAN2TID3 = sendMsg->canID; CAN2TDA3 = sendMsg->DataA; CAN2TDB3 = sendMsg->DataB; // Transmission Request on TX Buffer 3 CAN2CMR = 0x81; return 1; } else return 0; } return 0; }
If somenone could help me I will be very thankfull!
Thanks Genji
