I´m trying to get 02 USBTMC interfaces in a LXP1768 ARM7 with RL-ARM but the host just show me one. Anyone know if it´s possible? Any example....
Following the Configuration
/* USB Standard Device Descriptor */ const U8 USB_DeviceDescriptor[] = { USB_DEVICE_DESC_SIZE, /* bLength */ USB_DEVICE_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL(0x0200), /* 2.00 */ /* bcdUSB */ 0x00, /* bDeviceClass */ 0x00, /* bDeviceSubClass */ 0x00, /* bDeviceProtocol */ USB_MAX_PACKET0, /* bMaxPacketSize0 */ WBVAL(0xC251), /* idVendor */ WBVAL(0x2203), /* idProduct */ WBVAL(0x0100), /* 1.00 */ /* bcdDevice */ 0x01, /* iManufacturer */ 0x02, /* iProduct */ 0x03, /* iSerialNumber */ 0x01 /* bNumConfigurations: one possible configuration*/ }; /* USB Configuration Descriptor */ /* All Descriptors (Configuration, Interface, Endpoint, Class, Vendor) */ const U8 USB_ConfigDescriptor[] = { /* Configuration 1 */ USB_CONFIGUARTION_DESC_SIZE, /* bLength */ USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL( /* wTotalLength */ 1*USB_CONFIGUARTION_DESC_SIZE + 1*USB_INTERFACE_DESC_SIZE + 2*USB_ENDPOINT_DESC_SIZE + 1*USB_ENDPOINT_DESC_SIZE + 1*USB_INTERFACE_DESC_SIZE + 2*USB_ENDPOINT_DESC_SIZE ), 0x02, /* bNumInterfaces */ 0x01, /* bConfigurationValue: 0x01 is used to select this configuration */ 0x00, /* iConfiguration: no string to describe this configuration */ USB_CONFIG_BUS_POWERED /*|*/ /* bmAttributes */ /*USB_CONFIG_REMOTE_WAKEUP*/, USB_CONFIG_POWER_MA(100), /* bMaxPower, device power consumption is 100 mA */ /* Interface 0, Alternate Setting 0, MSC Class */ USB_INTERFACE_DESC_SIZE, /* bLength */ USB_INTERFACE_DESCRIPTOR_TYPE, /* bDescriptorType */ 0x00, /* bInterfaceNumber */ 0x00, /* bAlternateSetting */ 0x03, /* bNumEndpoints */ USB_DEVICE_CLASS_USBTMC, /* bInterfaceClass */ 0x03, /* bInterfaceSubClass */ 0x00, /* bInterfaceProtocol */ 0x04, /* iInterface */ /* Endpoint, EP2 Bulk IN */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_IN(2), /* bEndpointAddress */ USB_ENDPOINT_TYPE_BULK, /* bmAttributes */ WBVAL(0x0040), /* wMaxPacketSize */ 0x00, /* bInterval: ignore for Bulk transfer */ /* Endpoint, EP2 Bulk OUT */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_OUT(2), /* bEndpointAddress */ USB_ENDPOINT_TYPE_BULK, /* bmAttributes */ WBVAL(0x0040), /* wMaxPacketSize */ 0x00, /* bInterval: ignore for Bulk transfer */ /* Endpoint, EP2 Bulk OUT */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_IN(1), /* bEndpointAddress */ USB_ENDPOINT_TYPE_INTERRUPT, /* bmAttributes */ WBVAL(0x0040), /* wMaxPacketSize */ 0x20, /* bInterval: ignore for Bulk transfer */ /* Interface 0, Alternate Setting 0, MSC Class */ USB_INTERFACE_DESC_SIZE, /* bLength */ USB_INTERFACE_DESCRIPTOR_TYPE, /* bDescriptorType */ 0x01, /* bInterfaceNumber */ 0x00, /* bAlternateSetting */ 0x02, /* bNumEndpoints */ USB_DEVICE_CLASS_USBTMC, /* bInterfaceClass */ 0x03, /* bInterfaceSubClass */ 0x00, /* bInterfaceProtocol */ 0x05, /* iInterface */ /* Endpoint, EP2 Bulk IN */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_IN(3), /* bEndpointAddress */ USB_ENDPOINT_TYPE_BULK, /* bmAttributes */ WBVAL(0x0040), /* wMaxPacketSize */ 0x00, /* bInterval: ignore for Bulk transfer */ /* Endpoint, EP2 Bulk OUT */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_OUT(3), /* bEndpointAddress */ USB_ENDPOINT_TYPE_BULK, /* bmAttributes */ WBVAL(0x0040), /* wMaxPacketSize */ 0x00, /* bInterval: ignore for Bulk transfer */ /* Terminator */ 0 /* bLength */ };
> LXP1768
Do you mean NXP LPC1768 ?
The second interface assigns isoc endpoints of LPC1768 I'm not sure this is the cause, because your description is too vague for the host side.
- Host OS and version - Host class driver, NI, Agilent or other - Host application, which shows just one
For sloppy question, just sloppy answer will be returned.
Tsuneo
