I got a lot of errors after upgrade mdk 4.00 to mdk 4.10:
error: #5: cannot open source input file "stdio.h": No such file or directory error: #5: cannot open source input file "cstddef": No such file or directory error: #5: cannot open source input file "string.h": No such file or directory error: #5: cannot open source input file "rt_sys.h": No such file or directory
What's wrong with mdk4.10? I use UV3, I'm not going to use UV4 until I don't know how to disable new awful appearance ;)
Hi sad man,
maybe the same problem as in this thread: http://www.keil.com/forum/docs/thread16545.asp
You can track down the problem by using Process Monitor from sysinternals.
With this tool you can find out the search paths for stdio.h (and other files).
Robert
I really doubt that's necessary - possibly not even helpful.
It looks very much like a simple matter of the Project include paths being wrong:
Have you checked that "stdio.h" does, in fact, exist on your PC?
If it does, have you checked that your project is correctly configured to find it?
We had a similar issue with a TCPNet header file. We had to include the right path in the file properties (options for file...) to make it work. I think it has something to do with having installed more than one MDK version in different paths, but I'm not sure.
Yes, of course - you always have to specify the right path somehow!
There are many ways to do it; eg,
* In the Project properties - to apply to the whole Project;
* In the Group properties - to apply to the whole Group;
* In the File properties - to apply to an individual file.
You can, of course, even put a fully-qualified path in the source code; eg,
#include "C:/blah//Keil/blah/blah/includes/stuff.h"
And if you don't specify explicitly somehow in your Project and/or source, then the tools will use some default, which may or may not be what you need - especially if you've been installing and/or updating multiple versions...
Getting the include paths right is a standard part of any porting exercise - including an update of the tool versions.
Yes, but the strange thing was that as far as I could tell, the file was located at the right place (but still it was required to specify an explicit location). Personally I never had such issues, as I always install MDK update on top of each other (thus, into the same root path).
Project -> Options For Target '' -> C/C++ -> Include Paths insert "C:\Keil\ARM\RV31\INC;"
Why would it be RV31 ??
The OP said he had version 4.00, then 4.10 - so what would RV31 have to do with it??
