Hi all,
I am trying to set up my project with a Keil MCBSTM32C Eval Board using STM32F10x_StdPeriph_Lib which is provided with Keil's uVision. I have problems getting things running...
- In my main file, I include stm32f10x_lib.h which is in 'C:\Keil\ARM\INC\ST\STM32F10x' (default include path set by Keil to this directory).
- I added system_stm32f10x_cl.c, core_cm3.c, startup_stm32f10x_cl.s and STM32F10xR.LIB to my project.
- I also have stm32f10x_it.c and stm32f10_it.h in my project.
- I added my board support package (own implementation) to the project (file MCBSTM32C.c and MCBSTM32C.h). Here too, I include stm32f10x_lib.h in MCBSTM32C.h
Now, when building the app, I get errors:
Build target 'MCBSTM32C' compiling main.c... .\BSP\MCBSTM32C.h(233): error: #20: identifier "uint32_t" is undefined main.c(41): error: #20: identifier "__IO" is undefined main.c(41): error: #18: expected a ")" main.c(131): warning: #223-D: function "SystemInit" declared implicitly main.c(139): error: #20: identifier "__IO" is undefined main.c(139): error: #18: expected a ")" main.c(141): error: #20: identifier "nCount" is undefined compiling MCBSTM32C.c... BSP\MCBSTM32C.h(233): error: #20: identifier "uint32_t" is undefined BSP\MCBSTM32C.c(6): error: #20: identifier "uint16_t" is undefined BSP\MCBSTM32C.c(8): error: #20: identifier "uint32_t" is undefined BSP\MCBSTM32C.c(16): error: #20: identifier "uint16_t" is undefined BSP\MCBSTM32C.c(21): error: #20: identifier "uint32_t" is undefined BSP\MCBSTM32C.c(26): error: #20: identifier "uint16_t" is undefined BSP\MCBSTM32C.c(35): error: #20: identifier "uint16_t" is undefined BSP\MCBSTM32C.c(44): error: #20: identifier "uint16_t" is undefined BSP\MCBSTM32C.c(53): error: #20: identifier "uint16_t" is undefined BSP\MCBSTM32C.c(53): error: #20: identifier "EXTI0_IRQn" is undefined BSP\MCBSTM32C.c(53): error: #20: identifier "EXTI15_10_IRQn" is undefined BSP\MCBSTM32C.c(54): error: #20: identifier "EXTI9_5_IRQn" is undefined BSP\MCBSTM32C.c(62): error: #20: identifier "uint32_t" is undefined BSP\MCBSTM32C.c(64): error: #20: identifier "uint32_t" is undefined BSP\MCBSTM32C.c(66): error: #20: identifier "uint16_t" is undefined BSP\MCBSTM32C.c(68): error: #20: identifier "uint16_t" is undefined BSP\MCBSTM32C.c(250): error: #20: identifier "uint32_t" is undefined Target not created
I am worried about where the definitions of uint32_t, uint16_t, etc. should come from. Also __IO is undefined.
I am not sure if I am doing the exact right thing to use the periph lib that is provided with Keil. www.keil.com/.../mcbstm32c_ex_swlib.htm gives a short hint on how to use, but does not tell anything about required include files... My guess is that there is a "conflicht" between the stm32f10x_lib.h and stm32f10x_cl.h. When I also include stm32f10x_cl.h, there seems to be no problem wit the undefined identifiers, but I get tons of invalid redeclarations.
Any help highly appreciated! Thanks in advance!
-- Regards, Marco
