Adress space overflow
hi,
during compilation of my program i have been getting too many address overflow errors. Mostly the errors were due to function arguments placed in the data space instead of xdata...i solved it using the 'large' keyword..however now i get this error on a particular formula im implementing...viz."DecED1 = (DecCurrAss1 - DecReb1) * 0.125;" all of them are xdata float...how do i solve this..?
below is a part of the error log..
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?PR?_BUFFER2PAGE?STSBMV1 LENGTH: 0047H
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?PR?GET_KEY?STSBMV1 LENGTH: 0045H
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?PR?CF_BITS?STSBMV1 LENGTH: 0045H
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?C?LDIV LENGTH: 0044H
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?PR?DISP_INITIAL?STSBMV1 LENGTH: 0040H
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?PR?_CLR?FILEDOWNLOAD LENGTH: 003DH
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?PR?_DEBUG?FILEDOWNLOAD LENGTH: 003CH
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?PR?SOFTKEY_ON?STSBMV1 LENGTH: 003BH
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?PR?SCREENINIT?FILEDOWNLOAD LENGTH: 003BH
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?PR?_CONVERTDATE2?FILEDOWNLOAD LENGTH: 0037H
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?PR?_WRITE_OP?FILEDOWNLOAD LENGTH: 0036H
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?CO?MICRO1 LENGTH: 0036H
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?CO?MICRO2 LENGTH: 0036H
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?PR?DISP_TIME?STSBMV1 LENGTH: 0033H
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?PR?_DISP_MSGB?STSBMV1 LENGTH: 0031H
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?PR?_PRT_MSG?STSBMV1 LENGTH: 002EH
