do yOU need LCD (2 by 16) sample program in keil in C
Hi i'm kinda new here but this is my code for 16x2 Lcd
It was made with Keil uVision, Enjoy
#include <REGX52.H>
#define LCD_data P2
#define LCD_rs P1_0
#define LCD_rw P1_1
#define LCD_en P1_2
void LCD_busy(void);
void LCD_poweron(void);
void LCD_command(unsigned char var);
void LCD_senddata(unsigned char var);
void LCD_sendstring(unsigned char *var);
void LCD_init(void);
void main(void)
        unsigned char msg[] ="Learning";
        LCD_poweron();    // 15ms delay
                LCD_init();
                LCD_command (0x80);     // Set CGRAM adress,data is Avaible from uC
        LCD_sendstring(msg);
                while(1);
void LCD_busy()
    unsigned char i,j;
        for(i=0;i<50;i++)
                for(j=0;j<255;j++);
void LCD_poweron()
unsigned int i;
for (i=0;i<22500; i++);
     LCD_data  = var;      //Function set: 2 Line, 8-bit, 5x8 dots
     LCD_rs   = 0;        //Selected command register
     LCD_rw   = 0;        //We are writing in instruction register
     LCD_en   = 1;        //Enable H->L
     LCD_en   = 0;
     LCD_busy();          //Wait for LCD to process the command
     while(*var)              //till string ends
       LCD_senddata(*var++);  //send characters one by one
     P2  = var;      //Function set: 2 Line, 8-bit, 5x7 dots
     LCD_rs   = 1;        //Selected data register
     LCD_en   = 0;
void LCD_init(void)
     LCD_data = 0x38;     //Function set: 2 Line, 8-bit, 5x8 dots
     LCD_rw   = 0;        //We are writing in data register
     LCD_en   = 0;
     LCD_data  = 0x0F;     //Display on, Curson blinking command
     LCD_en   = 0;
     LCD_data  = 0x01;     //Clear LCD
     LCD_en   = 0;
     LCD_data  = 0x06;     //Entry mode, auto increment with no shift
         LCD_en   = 0;        //Enable H->L
     LCD_busy();
