This is in my 89C51RE2
/*------------------ T W I (I2C) registers ------------------------------*/ Sfr ( SSCON , 0x93);
Sbit (SSCR2 , 0x93, 7); Sbit (SSIEN , 0x93, 6); Sbit (SSSTA , 0x93, 5); Sbit (SSST0 , 0x93, 4); Sbit (SSSI , 0x93, 3); Sbit (SSAA , 0x93, 2); Sbit (SSCR1 , 0x93, 1); Sbit (SSCR0 , 0x93, 0);
This is the error I got while compiling 17 18 /* @section I N C L U D E S */ 19 //#include "reg_C51.h" 20 #include "89C51RE2.h" *** ERROR C142 IN LINE 227 OF 89C51RE2.H: 'SFR': invalid base address *** ERROR C142 IN LINE 228 OF 89C51RE2.H: 'SFR': invalid base address *** ERROR C142 IN LINE 229 OF 89C51RE2.H: 'SFR': invalid base address *** ERROR C142 IN LINE 230 OF 89C51RE2.H: 'SFR': invalid base address *** ERROR C142 IN LINE 231 OF 89C51RE2.H: 'SFR': invalid base address *** ERROR C142 IN LINE 232 OF 89C51RE2.H: 'SFR': invalid base address *** ERROR C142 IN LINE 233 OF 89C51RE2.H: 'SFR': invalid base address *** ERROR C142 IN LINE 234 OF 89C51RE2.H: 'SFR': invalid base address 21 char TWI_data; 22 char rw=0; /* 0=write, 1=read */ 23 char slave_adr; 24 bit b_TWI_busy=0;
Need help to fix this.
The messages tell you clearly what the problem is:
You need to check the Manual to see what constitutes a valid base address for an sbit - then ask yourself, do the values that you supplied meet those criteria...?
See also: http://www.keil.com/support/man/docs/c51/c51_c142.htm
Perhaps these would also help:
Chapter 1 - 80C51 Family Architecture: www.nxp.com/.../80C51_FAM_ARCH_1.pdf
Chapter 2 - 80C51 Family Programmer's Guide and Instruction Set: www.nxp.com/.../80C51_FAM_PROG_GUIDE_1.pdf
Chapter 3 - 80C51 Family Hardware Description: www.nxp.com/.../80C51_FAM_HARDWARE_1.pdf
8051 Tutorials: www.8052.com/tutorial.phtml
Books about the 8051: http://www.keil.com/books/8051books.asp www.8052.com/books.phtml
Thanks Andrew,
I will look into these docs and links.
Phillip
