Simulate Multiple I2C devices in Keil known code
I have been using code supplied by Keil to simulate I2C slaves and it works great......only problem.....its one device only. Using the VTREG's it does, I tried to modify the code by +1's on the call names, but that didn't work. I have at least 14 I2C slaves and would like the master to be able to simulate them all.....again it works if I adjust the I2C address for the single device I want to address. I'd like to try them all. Here is the original code:
// Simulation of I2C Memory (Slave)
MAP V:0,V:0xFF READ WRITE                    // Map User Memory region
DEFINE int SADR                              // Slave Address
signal void I2CMEMORY (void) {
  unsigned long adr;
  adr = V:0;
  while (1) {
    wwatch (I2C_OUT);                        // Wait for data from Microcontroller
    while (I2C_OUT == 0x0100) {              // START detected
      if (I2C_OUT > 0xFF) continue;
      if ((I2C_OUT >> 1) != SADR) continue;  // test if Slave is addressed
      I2C_IN = 0xFF00;                       // ACK to Microcontroller
      if (I2C_OUT & 1) {                     // Slave Read
        while (1) {
          I2C_IN = _RBYTE(adr);              // Read Byte from Memory
          adr++;                             // Increment Address
          wwatch (I2C_OUT);                  // Wait for ACK from Microcontroller
          if (I2C_OUT != 0xFF00) break;
      else {                                 // Slave Write
        adr = I2C_OUT | V:0;                 // Set Memory Address
        while (1) {
          if (I2C_OUT > 0xFF) break;
          _WBYTE (adr, I2C_OUT);             // Store Byte in Memory
SADR = 0x51
I2CMemory()
I tried:
signal void I2CMEMORY1 (void) {
  unsigned long adr;
  adr = V:0;
  while (1) {
        while (1) {
        while (1) {
SADR = 0x50
I2CMemory1()
signal void I2CMEMORY2 (void) {
  unsigned long adr;
  adr = V:10;
  while (1) {
        while (1) {
        while (1) {
SADR = 0x51
I2CMemory2()
The simulation doesn't crash, but the I2C interface doesn't work the interface properly anymore. Any thoughts on how to address this? I thought this would work since it is two different function in the same memory map space as local functions. I guess I'm missing something.
  • does the Keil simulation claim to support more than a single device?
    ie, does it not work because it isn't supposed to...?
  • You must check the address and data fields inside from ONE service routine.
    Depending which chip your tried to access different actions may happen.
    For example using 4 IO-chips (PCA9555) the address decided which from this chips is written to or read from.
    But the 'action' from processors 'point of view' is evereytime the same! ->i2c-isr.
    good luck :)
  • They don't claim either way, so since the memory map is defined, I would expect that having two seperate unique functions would we ok. I have an oscillator running from VTREG's and one I2C slave. There isn't much to go on except the example and the fact that it does work with one.
    I think I may have found the issue I mentioned on 8052 and as I mess with it more, I recall your help in the past about no precompilier directives, I think one of my errors is one of my defines are in the wrong location.
    I'll give that a try and post up the code if I can get it to work.
    Any other thoughts are more than welcome.
    Regards,
  • Gunter, all of my code already works and follows what you said, my issue is Keil simulating several devices within the single .ini file. So the example code must be replicated 4 times with unique values and address for each "individual" slave. As it stands now, I have to save SADR = to the value of what is needed for each individual slave. Makes time consuming to test blocks of code, so adding several with w/r capability will make the simulation easy to work with.
  • Issue has been solved, just some added syntax to get it going
