Startup.s erorrs
I am new to uVision and assembly. I am trying to build a project that i found on the internet.
When i press the build button in uVision3 it starts assembling my startup.s file.
But it gives an error on every line!
It says bad instruction!
I read somewhere on this forum that uVision should just compile the startup file (with assembly). But it does not with this file?
I am using a GNU compiler (winarm) and the project is for the evaluation board for the LM3S811
I add the startup file because there is maybe a something wrong with?! I think i all so need to fill in some lines because it is a standard startup file for my processor, but i don not know how to do this.
Thanks for all your help already!
Stack EQU 0x00000100
Heap EQU 0x00000000
AREA STACK, NOINIT, READWRITE, ALIGN=3
StackMem SPACE Stack
__initial_sp
AREA HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
HeapMem SPACE Heap
__heap_limit
PRESERVE8
AREA RESET, CODE, READONLY THUMB
EXPORT __Vectors
__Vectors
DCD StackMem + Stack
DCD Reset_Handler
DCD NmiSR
DCD FaultISR
DCD IntDefaultHandler
DCD 0
DCD 0
DCD 0
DCD 0
DCD 0
DCD 0
EXPORT Reset_Handler
Reset_Handler
IMPORT __main B __main
NmiSR B NmiSR
FaultISR B FaultISR
IntDefaultHandler B IntDefaultHandler
ALIGN
AREA |.text|, CODE, READONLY
IF :DEF: __MICROLIB
EXPORT __initial_sp
EXPORT __heap_base
EXPORT __heap_limit
ELSE
IMPORT __use_two_region_memory
EXPORT __user_initial_stackheap
LDR R0, =HeapMem
LDR R1, =(StackMem + Stack)
LDR R2, =(HeapMem + Heap)
LDR R3, =StackMem
BX LR
ENDIF
ALIGN
END
  • Please use the 'pre' markup tags to format the code when posting a message, like so:
    code line 1
    code line 2
    code line 3
    code line 4
    etc.
  • Oke thanks for the tip.
    Here is the code again (now also with comments)
    Reset_Handler
            ; Call the C library enty point that handles startup.  This will copy
            ; the .data section initializers from flash to SRAM and zero fill the
            ; .bss section.  It will then call __rt_entry, which will be either the
            ; C library version or the one supplied here depending on the
            ; configured startup type.
            IMPORT  __main
            B       __main
    ; This is the code that gets called when the processor receives a NMI.  This
    ; simply enters an infinite loop, preserving the system state for examination
    ; by a debugger.
    NmiSR
            B       NmiSR
    ; This is the code that gets called when the processor receives a fault
    ; interrupt.  This simply enters an infinite loop, preserving the system state
    ; for examination by a debugger.
    FaultISR
            B       FaultISR
    ; This is the code that gets called when the processor receives an unexpected
    IntDefaultHandler
            B       IntDefaultHandler
    ; Make sure the end of this section is aligned.
            ALIGN
    ; Some code in the normal code section for initializing the heap and stack.
    ; The function expected of the C library startup code for defining the stack
    ; and heap memory locations.  For the C library version of the startup code,
    ; provide this function so that the C library initialization code can find out
    ; the location of the stack and heap.
        IF :DEF: __MICROLIB
            EXPORT  __initial_sp
            EXPORT  __heap_base
            EXPORT  __heap_limit
        ELSE
            LDR     R0, =HeapMem
            LDR     R3, =StackMem
            BX      LR
        ENDIF
            ALIGN
    ; Tell the assembler that we're done.
            END
  • Can't help you with ARM specific things, sorry.
    But my suggestion would be to split things into smaller tasks.
    - are you sure the (assembly and C) source code is suitable for your toolchain? Does it contain toolchain specific instructions? See also my comment in your other thread
    http://www.keil.com/forum/docs/thread12940.asp
    - did you manage to get a HelloWorld-like demo application to work on the evaluation board, using the default toolchain? It should come with plenty of instructions en demos I assume. The demos should also come with a startup file you might be able to reuse.
    - then convert the small demo application to the new toolchain and get it running (I guess you need this to build larger projects because of license issues; but don't forget to check out educational licenses!)
    - then modify the demo application to include your own code.
    ...little steps.
    Joost
