volertale variebles or eeprom mem ory
I got the question about volatile variebles and eeprom memory. (I use C and IDE)
First of all, I have a program that has to remember a variable's value even if I reset the thing (this value changes between 0 - 9 so it is an unsigned char). The details and the program is below ;
*counter is my variable that I change value via interrupt and push button
*counter is my variable that microcontroller has to remember after reset
*counter is my variable that can be changed by both main and interrupt
volatile unsigned char counter;
void interrupt()
  counter++;
  Delay_ms(150);
  if(counter == 10)
  counter=0;
  while(bit is zero);
  Delay_ms(20);
  SFRA=0xD0;
void main()
  for(;
    if(counter == 0)
       .....program writes 7 seg the value of counter
     if(counter == 1)
     if(counter == 2)
     if(counter == 3)
     if(counter == 4)
     if(counter == 5)
     if(counter == 6)
     if(counter == 7)
      ......program writes 7 seg the value of counter
      if(counter ==
       ........program writes 7 seg the value of counter
      if(counter == 9)
Now, this program does not work properly it loses the value of counter. I got two choices;
1. declaring counter variable as a volatile  (but I could not succeed)
2. using eeprom memory but this will increase my loop time.
Please help me   I am confused.
  • eeprom memory.
    WHICH? built-in/IIC/SPI/parallel/serial/
    (I use C and IDE)
    irrelevant
  • The "volatile" keyword has nothing to do with a variable surviving a reset. It just informs the compiler that some unknown external force may modify the variable at any time, so the compiler may not assume that it can keep a copy of the variable in a register and reuse multiple times.
    For nonvolatile storage, i.e. data that should be kept even if the processor is reset or after a power loss, you must use EEPROM, flash, battery-backed RAM, FRAM or similar, i.e. you must use a memory type that is capable of retaining data when your equipment is not powered.
