ADUC7024 IRQ not working properly
I am trying to build a counter using an ADUC7024. Basically I want Timer0 to cause a global interrupt every 10ms. Timer1 should be counting my input TTL pulses.
Every time it interrupts, I want the DAC to output a voltage proportional to the number of counts on Timer1 in that 10ms period.
Here is my counter.c file
#include<ADuC7024.h>
void IRQ_Handler(void) ;
int main (void)  {
        T0LD = 0x3FC0;  // Counter Value
        T0CON = 0xC8;
// Enabled,Periodic,Binary and CLK/256
        T1LD = 0x00000000;
// Load zero to timer one initial value
        T1CON = 0x00000780;
// Enabled,count P0.6
        IRQ = IRQ_Handler;
// Specify Interrupt Service Rountine
        IRQEN = RTOS_TIMER_BIT; // Enable Timer0 IRQ
        DAC0CON = 0x13;
        DAC0DAT = 0x0FFF0000;
        while (1)
        DAC0DAT = T1VAL << 16;
        T1CON ^= 0x00000040;
        if ((IRQSTA & 0x00000004) != 0)      // Timer0 IRQ?
                GP4DAT ^= 0x00040000;// Complement P4.2
                T0CLRI = 0x1;   // Clear Timer IRQ
                IRQCLR = 0x00000004;
        return ;
And I am using the default ADUC702x.s file. I know I need to change something with the IRQ Handlers but I don't know what. I've checked the boards and can't find anything usable for me.
Now the problem I'm getting is as my response when I build it.
Build target 'ADuC7024 Flash'
assembling ADuC702x.s...
compiling counter.c...
linking...
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol DAbt_Handler (referred from aduc702x.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol FIQ_Handler (referred from aduc702x.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol PAbt_Handler (referred from aduc702x.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol Undef_Handler (referred from aduc702x.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol IRQ (referred from counter.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_irq_ack_lock (referred from rt_hal.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol tsk_unlock (referred from rt_hal.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_stackinfo (referred from rt_hal.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_stk_overflow (referred from rt_hal.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_tmr_force_irq (referred from rt_system.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_tmr_inspect_cnt (referred from rt_system.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_tmr_inspect_ovf (referred from rt_system.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol m_tmr (referred from rt_task.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol mp_stk (referred from rt_task.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol mp_stk_size (referred from rt_task.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol mp_tcb (referred from rt_task.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol mp_tcb_size (referred from rt_task.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol mp_tmr_size (referred from rt_task.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_active_TCB (referred from rt_task.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_idle_demon (referred from rt_task.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_maxtaskrun (referred from rt_task.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_rrobin (referred from rt_task.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_tmr_init (referred from rt_task.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol tsk_lock (referred from rt_task.o).
.\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_tmr_call (referred from rt_timer.o).
Target not created
Can anyone help? email is j.d.ellis@tudelft.nl
