I'm using TCPNET and the RTX kernel on an STR912 ARM9.
A simple question first: can TCPNET be configured to respond to a broadcast PING?
Second, I have noticed that sometimes the response time to PINGs gets erratic and long. Normally the response time is ~1ms, but sometimes (for no reason I have been able to debug yet) the response times go up to 1 or 2 seconds (frequently almost exactly 1 or 2 seconds).
The only cure seems to be to power-cycle my board. This happens both on my own board and on an STRB9 from Keil. When I was running the http demo I noticed that when the ping time goes up, the HTTP response also becomes very slow. What is happening?
Christopher Hicks ==
NORMAL:
hiss:~# ping 192.168.2.12 PING 192.168.2.12 (192.168.2.12) 56(84) bytes of data. 64 bytes from 192.168.2.12: icmp_seq=1 ttl=128 time=1.03 ms 64 bytes from 192.168.2.12: icmp_seq=2 ttl=128 time=0.967 ms 64 bytes from 192.168.2.12: icmp_seq=3 ttl=128 time=0.998 ms 64 bytes from 192.168.2.12: icmp_seq=4 ttl=128 time=1.00 ms 64 bytes from 192.168.2.12: icmp_seq=5 ttl=128 time=0.908 ms
SOMETIMES:
hiss:~# ping 192.168.2.12 PING 192.168.2.12 (192.168.2.12) 56(84) bytes of data. 64 bytes from 192.168.2.12: icmp_seq=1 ttl=128 time=352 ms 64 bytes from 192.168.2.12: icmp_seq=2 ttl=128 time=2001 ms 64 bytes from 192.168.2.12: icmp_seq=3 ttl=128 time=1940 ms 64 bytes from 192.168.2.12: icmp_seq=4 ttl=128 time=941 ms 64 bytes from 192.168.2.12: icmp_seq=5 ttl=128 time=1001 ms 64 bytes from 192.168.2.12: icmp_seq=6 ttl=128 time=1186 ms 64 bytes from 192.168.2.12: icmp_seq=7 ttl=128 time=1011 ms 64 bytes from 192.168.2.12: icmp_seq=8 ttl=128 time=510 ms
On MCB2300 demo board vers. 3, using HTTP-Demo keil example, i have done as follows: 1) load application and let it run, in debug mode 2) start ping demo board: response time < 1ms 3) stop application wih debugger (obviously after a few seconds i see "ping timeout" on my pc) 4) restart application 5) after a few seconds, ping resumes but response time is very long (1000ms and more).
