LIB CODE size problem
I have problem with code size. When I check the map file it shows LIB CODE size 631h as follows
CODE 0076H 0631H UNIT ?C?LIB_CODE
why LIB CODE size such big? what could be the reason?.
FYI: Below are MAP file information for library routine inclusion. I
C:\KEIL\C51\LIB\C51FPC.LIB (?C?FPADD) C:\KEIL\C51\LIB\C51FPC.LIB (?C?FPMUL) C:\KEIL\C51\LIB\C51FPC.LIB (?C?FPDIV) C:\KEIL\C51\LIB\C51FPC.LIB (?C?FPCMP) C:\KEIL\C51\LIB\C51FPC.LIB (?C?FCAST) C:\KEIL\C51\LIB\C51FPC.LIB (?C?CASTF) C:\KEIL\C51\LIB\C51FPC.LIB (?C?FPGETOPN) C:\KEIL\C51\LIB\C51C.LIB (?C_STARTUP) C:\KEIL\C51\LIB\C51C.LIB (?C?COPY) C:\KEIL\C51\LIB\C51C.LIB (?C?CLDPTR) C:\KEIL\C51\LIB\C51C.LIB (?C?CLDOPTR) C:\KEIL\C51\LIB\C51C.LIB (?C?CSTPTR) C:\KEIL\C51\LIB\C51C.LIB (?C?IMUL) C:\KEIL\C51\LIB\C51C.LIB (?C?UIDIV) C:\KEIL\C51\LIB\C51C.LIB (?C?LNEG) C:\KEIL\C51\LIB\C51C.LIB (?C?LLDIDATA) C:\KEIL\C51\LIB\C51C.LIB (?C?LLDIDATA0) C:\KEIL\C51\LIB\C51C.LIB (?C?LSTIDATA) C:\KEIL\C51\LIB\C51C.LIB (?C?CCASE) C:\KEIL\C51\LIB\C51C.LIB (?C?ICASE) C:\KEIL\C51\LIB\C51C.LIB (?C?MEMSET) C:\KEIL\C51\LIB\C51C.LIB (?C_INIT)
Thanks in advance
  • Probably because your using floating point math routines.
  • "why LIB CODE size such big? what could be the reason?."
    Because you are using code-hungry features!
    As already mentioned, the ?C?FP... libraries are all to do with Floating-Point arithmetic - you cannot hope to have small code and use floating point on an 8051!!
    Another space-hog is printf
    See this thread: http://www.keil.com/forum/docs/thread1343.asp and the linked knowledgebase article: http://www.keil.com/support/docs/1958.htm
    You probably need to study the section on "writing optimum code" in the C51 Manual...
    (sorry, the online manuals seem to be down at the moment - can't post a link)
  • I need division arithmetic in which the numerator is less than denominator(decimal 255 fixed) example 3/255, in that case what can I do to avoid using floating point variables. Only in 2 places I have instructions like that.
    Just to check coding size I change the variable to unsigned long and compiled again and CODE size reduced by almost 1 KB. But as you knew I could not get the correct result out that division arithmetic instructions.
    Any further advice? please reply.
  • 3/255 = 0.0117647.
    (3*10) / 255 = 0
    (3*100) / 255 = 1
    (3*1000) / 255 = 11
    (3*10000) / 255 = 117
    using unsigned long
    (3*100000ul) / 255 = 1176
    (3*1000000ul) / 255 = 11764
  • But as you knew I could not get the correct result out that division arithmetic instructions.
    Interesting you should say that, since you're using floating-point arithmetics. That won't give you "the correct" result very often, either.
    Before you can qualify correctness of a result, you have to decide how this result should be represented. Fixed-point is often preferable over floating-point, particularly on a '51. Fractions may be even better. E.g. the simplest representation in this case would be in units of 1/255.
