typedef struct { int query_zone:4; }statusrequest_t; statusrequest_t state; state.query_zone=8; if ( state.query_zone==8) printf("The result matches n=%i n\r",state.query_zone); else printf("This should not occur n=%i\n\r",state.query_zone);
CARM produces : This should not occur n=-8 RV produces : The result matches n=8
typedef struct { short query_zone:4; }statusrequest_t;
CARM produces : The result matches n=8 RV produces : This should not occur n=-8
typedef struct { signed char query_zone:4; }statusrequest_t;
Why does the comparision fail when query_zone is an int bitfield ? The RV compiler produces not the same result as CARM
Assuming a twos-complement representation, a 4-bit (implicitly signed) integer can hold values in the range -8 through 7. 8 is not in that range.
The Standard states that it is implementation-defined whether a bitfield declared without signed or unsigned qualifiers is interpreted as signed or unsigned. When used in expressions, the bit-field value is promoted to the int arithmetic type either signed or unsigned.
The RV 3.0 Compiler & Libraries MANUAL documents the bit-field allocation rules, and states that unqualified bit-fields are interpreted as unsigned.
This is why bitfield declarations should always be explicitly sign-qualified, to stay away of compiler implementation choices.
Your first and last examples for RV are consistent with the manual: the first one is 8, and the last is -8 (binary 1000 sign-extended to 0xFFFFFFF8 in signed 2's complement).
But your second example is not right. A short bitfield should evaluate to 8, like the first example. I couldn't reproduce your declared behaviour. Are you sure RV is returning -8 for the short bitfield example?
Noel, are you still following this thread anymore? Can you give feedback?
i will look again at the problem, i am not in the possibility to do this in the next coming days.
