Errors using library
I have a library "library.a" and I am trying to use it with GNU compiler. As a base I take 'measure' project from examles which is compiling ok without library, but when I am trying to compile project with "library.a" I get a lot of errors like this:
assembling Startup.s...
compiling Measure.c...
linking...
/cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/../../../../arm-thumb-elf/bin/ld: ERROR: /cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/../../../../arm-thumb-elf/lib/libc.a(__uClibc_main.o) is compiled for EABI version 0, whereas .\Obj\Measure.elf is compiled for version 2
File format not recognized: failed to merge target specific data of file /cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/../../../../arm-thumb-elf/lib/libc.a(__uClibc_main.o)
/cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/../../../../arm-thumb-elf/bin/ld: ERROR: /cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/../../../../arm-thumb-elf/lib/libc.a(strcpy.o) is compiled for EABI version 0, whereas .\Obj\Measure.elf is compiled for version 2
File format not recognized: failed to merge target specific data of file /cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/../../../../arm-thumb-elf/lib/libc.a(strcpy.o)
/cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/../../../../arm-thumb-elf/bin/ld:  ERROR: /cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/../../../../arm-thumb-elf/lib/libc.a(sigrestorer.o) is compiled for EABI version 0, whereas .\Obj\Measure.elf is compiled for version 2
File format not recognized: failed to merge target specific data of file /cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/../../../../arm-thumb-elf/lib/libc.a(sigrestorer.o)
/cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/../../../../arm-thumb-elf/bin/ld: ERROR: /cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/crtend.o is compiled for EABI version 0, whereas .\Obj\Measure.elf is compiled for version 2
File format not recognized: failed to merge target specific data of file /cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/crtend.o
/cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/../../../../arm-thumb-elf/bin/ld: ERROR: /cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/crtn.o is compiled for EABI version 0, whereas .\Obj\Measure.elf is compiled for version 2
File format not recognized: failed to merge target specific data of file /cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/crtn.o
/cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/../../../../arm-thumb-elf/bin/ld: region DATA is full (.\Obj\Measure.elf section .bss)
Does it mean that my "library.a" is intended for another version of GCC?
