EZ-USB FX2LP CY7C68013A: target not created!
I'm developing a project with micro
When I try to build project, I get that message
Build target 'Target 1'
compiling fw.c...
assembling dscr.a51...
compiling firmware.c...
compiling clocksys.c...
compiling SPI.c...
compiling gpif.c...
linking...
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
    SEGMENT: ?PR?_GPIFSINGLEWORDWRITE?FIRMWARE
    SEGMENT: ?PR?_GPIFSINGLEWORDREAD?FIRMWARE
*** ERROR L107: ADDRESS SPACE OVERFLOW
    SPACE:   DATA
    SEGMENT: ?DT?SPI
    LENGTH:  0064H
*** ERROR L118: REFERENCE MADE TO ERRONEOUS EXTERNAL
    SYMBOL:  VETTORETIMERTO
    MODULE:  .\Obj\fw.obj (FW)
    ADDRESS: 0576H
    ADDRESS: 059FH
    ADDRESS: 05A1H
    SYMBOL:  FASERXTXSPI
    MODULE:  .\Obj\firmware.obj (FIRMWARE)
    ADDRESS: 0277H
    SYMBOL:  _FLAGDIRSPIBUF
    ADDRESS: 0279H
    SYMBOL:  FASERXTXSPI
    ADDRESS: 16A6H
    ADDRESS: 16A8H
*** ERROR L105: PUBLIC REFERS TO IGNORED SEGMENT
    SYMBOL:  NUMBYTEDATAPKT
    SEGMENT: ?DT?SPI
    SYMBOL:  VERIFICARX
    SEGMENT: ?DT?SPI
    SYMBOL:  NUMRXSPI
    SEGMENT: ?DT?SPI
    SYMBOL:  SLAVEENABLE
    SEGMENT: ?DT?SPI
    SYMBOL:  NUMBYTETXED
    SEGMENT: ?DT?SPI
    SYMBOL:  NUMBYTERXED
    SEGMENT: ?DT?SPI
    SYMBOL:  _TIPOCOMANDOSPI
    SEGMENT: ?DT?SPI
    SYMBOL:  _BUFFERSPI
    SEGMENT: ?DT?SPI
    SEGMENT: ?DT?SPI
    SYMBOL:  _FASECOMANDOSPI
    SEGMENT: ?DT?SPI
    SEGMENT: ?DT?SPI
    SYMBOL:  FASERXTXSPI
    SEGMENT: ?DT?SPI
Program Size: data=195.6 xdata=4749 code=6206
Target not created
Any hint? Thanks in advance.
  • *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?_GPIFSINGLEWORDWRITE?FIRMWARE
    *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?_GPIFSINGLEWORDREAD?FIRMWARE
    get rid of the above
    1) comment out the functions
    2) enclose the functions in #ifdef (something undefined) #endif
    3) if not optimizing call them this way:
    if (0)
    { GPIFSINGLEWORDWRITE();
    GPIFSINGLEWORDREAD();
    } either should do the trick
    I like 3) because it maintains the call tree and thus there are no 'surprises' when you include the calls to these functions
    Note to Jon:
    why does "either should do the trick" carwl up to be after the } there is a CR after the }
  • FIRST you have to get rid of all 'ignored', 'erroneous' and 'uncalled' stuff.
    THEN (and only then) if you still have ERROR L107: ADDRESS SPACE OVERFLOW
    you will have to move some variables out of 'data' by adding the IDATA or XDATA qualifier.
