Minor complaint :not pick up SSFcc2A.obj when the pseudo op NAME has the same operand
if not exist as.lib goto usliex
del as.lib
:usliex
c:\tools\keil\c51\bin\lib51 c as.lib					>..\trash\trashbin
c:\tools\keil\c51\bin\lib51 a Sacode.obj	to as.lib	>..\trash\trashbin
c:\tools\keil\c51\bin\lib51 a Sccode.obj	to as.lib	>..\trash\trashbin
c:\tools\keil\c51\bin\lib51 a SSF881C.obj  	to as.lib	>..\trash\trashbin
c:\tools\keil\c51\bin\lib51 a SSF882C.obj  	to as.lib	>..\trash\trashbin
c:\tools\keil\c51\bin\lib51 a SSF882M.obj  	to as.lib	>..\trash\trashbin
c:\tools\keil\c51\bin\lib51 a SSFcc1C.obj  	to as.lib	>..\trash\trashbin
c:\tools\keil\c51\bin\lib51 a SSFcc2A.obj  	to as.lib	>..\trash\trashbin
c:\tools\keil\c51\bin\lib51 a SSF901C.obj  	to as.lib	>..\trash\trashbin
c:\tools\keil\c51\bin\lib51 a Scrout.obj  	to as.lib	>..\trash\trashbin
c:\tools\keil\c51\bin\lib51 a Sarout.obj  	to as.lib	>..\trash\trashbin
c:\tools\keil\c51\bin\lib51 a Sfmtbs.obj  	to as.lib	>..\trash\trashbin
c:\tools\keil\c51\bin\lib51 a Sfmtbm.obj  	to as.lib	>..\trash\trashbin
c:\tools\keil\c51\bin\lib51 a Sssgchar.obj  to as.lib	>..\trash\trashbin
c:\tools\keil\c51\bin\lib51 a Sssbmap.obj   to as.lib	>..\trash\trashbin
REM if "%MUSTYP%"=="a" goto lnkac
REM c:\tools\keil\c51\bin\bl51 SSLstart.obj, SSLisr.obj, SSLiic.obj, Smain.obj, Sxdata.obj, as.lib, c51s.lib TO as.omf RS(256) IX >protl.log
REM goto lnkdn
REM
REM :lnkac
REM c:\tools\keil\c51\bin\bl51 Sstart.obj, Sisr.obj, Siic.obj, Smain.obj, SSFcc2A.obj, Sxdata.obj, as.lib, c51s.lib TO as.omf RS(256) IX >protl.log
    c:\tools\keil\c51\bin\bl51 Sstart.obj, Sisr.obj, Siic.obj, Smain.obj,              Sxdata.obj, as.lib, c51s.lib TO as.omf RS(256) IX >protl.log
The above link a version that uses SSFcc1c without problems. Another version that uses ssfcc2a require that the link line be replaced with the REM ... above.
I just recalled what the problem is, so, instead of a question, this is a "minor complaint" When the pseudo op NAME has the same operand in two modules, only one of the objexts get to the library.
