Hello, my code passes compilation fine when using small or large models. however when changing the project to use compact model, I get the following errors, (which seem like library bugs) (???):
linking... *** ERROR L121: IMPROPER FIXUP MODULE: C:\KEIL\C51\LIB\C51FPC.LIB (PRINTF) SEGMENT: ?PR?PRINTF?PRINTF OFFSET: 0068H *** ERROR L121: IMPROPER FIXUP MODULE: C:\KEIL\C51\LIB\C51FPC.LIB (LOG) SEGMENT: ?PR?LOG?LOG OFFSET: 0087H *** ERROR L121: IMPROPER FIXUP MODULE: C:\KEIL\C51\LIB\C51FPC.LIB (LOG) SEGMENT: ?PR?LOG?LOG OFFSET: 00AFH *** ERROR L121: IMPROPER FIXUP MODULE: C:\KEIL\C51\LIB\C51FPC.LIB (LOG) SEGMENT: ?PR?LOG?LOG OFFSET: 00C8H *** ERROR L121: IMPROPER FIXUP MODULE: C:\KEIL\C51\LIB\C51FPC.LIB (LOG) SEGMENT: ?PR?LOG?LOG OFFSET: 00D5H *** ERROR L121: IMPROPER FIXUP MODULE: C:\KEIL\C51\LIB\C51FPC.LIB (LOG) SEGMENT: ?PR?LOG?LOG OFFSET: 00F0H *** ERROR L121: IMPROPER FIXUP MODULE: C:\KEIL\C51\LIB\C51FPC.LIB (LOG) SEGMENT: ?PR?LOG?LOG OFFSET: 010DH *** APPLICATION REQUIRES RE-TRANSLATIONS! *** Program Size: data=133.7 xdata=1795 code=15338 Target not created
