I have been trying to run the demo program in the C51: IN-SYSTEM FLASH PROGRAMMING (PART 2) artical on the dallas 80c400 in contiguout mode. the only changes I have made are: change device to 80c400 change memory model: Large code rom size: contiguous: 16M far memory support. but when I build the code I get the following errors. Any idea what I am doing wrong? *** ERROR L127: UNRESOLVED EXTERNAL SYMBOL SYMBOL: _CODE_FLASHMEM_L_ MODULE: Srom.obj (SROM) *** ERROR L127: UNRESOLVED EXTERNAL SYMBOL SYMBOL: _CODE_FLASHMEM_S_ MODULE: Srom.obj (SROM) *** ERROR L127: UNRESOLVED EXTERNAL SYMBOL SYMBOL: _CODE_FLASHMEM_T_ MODULE: Srom.obj (SROM) *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: _CODE_FLASHMEM_L_ MODULE: Srom.obj (SROM) ADDRESS: 10000CEH *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: _CODE_FLASHMEM_L_ MODULE: Srom.obj (SROM) ADDRESS: 10000D0H *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: _CODE_FLASHMEM_S_ MODULE: Srom.obj (SROM) ADDRESS: 10000D2H *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: _CODE_FLASHMEM_S_ MODULE: Srom.obj (SROM) ADDRESS: 10000D4H *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: _CODE_FLASHMEM_T_ MODULE: Srom.obj (SROM) ADDRESS: 10000D8H *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: _CODE_FLASHMEM_T_ MODULE: Srom.obj (SROM) ADDRESS: 10000DAH
Hi John, I have exact problem, but if I switch to code rom size "Large: 64kB program" it works well. I don't know, why the linker does not support the "SROM" functionality in contiguous mode. Andreas
yeh, I got the same response from keil tech support "This example won't work in contiguous mode. It will work if you change back to Large ROM size.".... sound s like they told you the same thing. I don't know whats wrong with the tech support on this issue, they just seem to want to ignore us, tell us it won't work, and to go away. the solution is actually very simple... change all references of "CODE" to "ECODE" in pflash.c and srom.c
Hi John, thanks a lot for Your reply. Now the example is working and I can extend it to my project. Andreas
just thought I would pass a warning onto to you about a bug I encountered (and spent all day yesterday tracking down) relating to this. my board has flash at 0x200000 (rather than ram as in the tini) it seems SROM_MC_SRC returns the correct value if my code <64K (i.e. if code starts at 0x200000 and the address of the segment is 0x206E5A SROM_MC_SRC returns a generic pointer with value 0xa16e5a as expected) however if the code is over 64K it returns the generic pointer with an incorrect xbyte (i.e. if code starts at 0x200000 and the address of the segment is 0x21D097 SROM_MC_SRC returns a generic pointer with value 0xa1d097 ... the generic pointer should be 0xa2d097).... so the wrong code gets copied to RAM.
John and/or Andreas, Please email me. Thanks, Iftah
an email adress would help
iftah@web-silicon.com Thanks, Iftah
i am working on 80c400 i problem for programmin the device can any 1 help me Suhas
Could you detail your problem?
In one documentation i ve refered mentions ISP for HIGH speed Microcontrlllers I used the ckt fro DS80c420 its fine will the same ckt be helpfull for CS 80c400 as far as ISP is concerned can any 1 help me Regards Suhas
